Question about Watches
How to change the battery on my fmdcy100 golf watch? what battery also? thanks
What is the battery number for a tag heuer tw professional golf watch
  • Open back
  • Find battery holder
  • Identify battery type (not number)
Nov 21, 2016 | Tag Heuer Watches
New battery for watch gps
Fixya does not sell batteries.
Nov 21, 2016 | Watches
It died and won't charge or turn on
could be the battery .. try taking the back off,take battery out and leave the battery out for 10 minuets ..then put it back in . this could help restart the charging cycle . if not then you'll need a new battery
Apr 24, 2015 | Garmin Approach S3 Touchscreen Golf Watch
How do I get the back off a Callaway CY 2001 watch? There is no indent to prise it off. Thanks
This watch is water-resistant to 5ATM (atmospheres), which means that you have to use a machine or a special tool to reseal the back of it to keep it water-resistant. If you do manage to get the back off, you'd probably end up cracking the crystal when you try to put the back on after replacing the battery.
I would suggest taking it to a locally-owned jewelry shop-- shouldn't cost more than $5-10, which isn't bad for a watch that probably cost you almost $100.
May 04, 2011 | Callaway Golf Sport watch#CY2058 Watch for...
Dont know how to change the battery in my callaway golf warbird watch
Thank you for contacting Fixya.
Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal. You can find this sometimes by running your fingernail around the back rim, as this tab or indentation can be hard to see.
  • Pull out the stem, which releases the back on some watches.
  • Get a small flathead screwdriver it needs to be a thin inflexible tip. Use a kitchen knife as a last resort. Wrap the hand you are holding the watch with in a towel or protect your hand in some manner so you don't injure yourself if the screwdriver/knife slips.
  • Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  • Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  • When you replace the cover, make sure you line up the stem slot on the cover with the stem of the watch.
  • Best regards. Jewel
    Aug 27, 2010 | Callaway Quartz Golf Watch
    Does not keep time
    mcdevito75 here, Yes and No, While any sharp, sudden, or very hard motion of your hand, wrist or arm can hurt a watch, it seldom does, most of the time you"d have to actually bang the watch against a hard surface, Wall, Floor etc to effct the movement, and usually you just scratch the crystal or caseing. .
    Jul 15, 2010 | Baume Et Mercier Baume & Mercier 18k Gold...
    Pull the crown half way out to set the date. To set the day, keep advancing the time - 24 hours for each day. The day will change at midnight each 24 hours. It's a time consuming but one-time-only effort as long as the battery is good.
    Sep 25, 2009 | Callaway Golf Sport Series Chronograph...
    Watches Logo
    80 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
