Question about Infiniti Vehicle Parts & Accessories
Cannot start engine security system is locked
  • 10,515 Answers
Kindly mention the year, make and model of the car?
Thanks!!
Posted on Sep 12, 2010
  • mawmak Nov 10, 2010
    1996 Infiniti - battery new but when the key is put in ignition won't start. Car tow company said it was security system. How do we disengage the security system?
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2000 grand am security light comes on can i bypass that with remote start
Are you the one who bought the vehicle new ? Replaced ignition switch or the ignition lock cylinder ? No , sorry, but a remote start will not by pass anti-theft system .
The vehicle theft deterrent system is designed in order to prevent vehicle theft by disabling the fuel injectors unless the lock cylinder is correctly engaged by a mechanical key. The theft deterrent system uses the following 4 components for theft prevention:
• The lock cylinder
• The ignition switch
• The body control module (BCM)
• The powertrain control module (PCM)
When starting the engine, the PCM searches for a password from the BCM through the Class 2 serial data circuit. If the password is not recognized or not present, the PCM will disable the engine. Two modes of tamper detection are provided:
No password received
The engine will start and stall quickly. SECURITY telltale will flash on the instrument panel cluster (IPC) and then stay ON steady.
Incorrect or disable password received (More than 3 invalid passwords are received)
The engine is disabled for at least 10 minutes and the SECURITY telltale will illuminate solid on the IPC during the 10 minutes.
After the vehicle has passed theft detection, the PCM will continue normal operation.
Jan 09, 2017 | Cars & Trucks
Where is the fuse for security light in 96 pontiac bonneville??
Try using the door key to lock and un lock the drivers door. Pulling the fuse for the security system will guarantee the engine will never start.
Sep 29, 2016 | Pontiac Bonneville Cars & Trucks
How do i reset the alarm on my 2003 Chevy Trailblazer...I can't stay my truck.
Hello Narisol,
Excerpt from the 2003 Owners Manual.
Passlock
Your vehicle is equipped with the Passlock theft-deterrent
system. Passlock is a passive theft-deterrent system.
Passlock enables fuel if the ignition lock cylinder is turned with a valid key. If a correct key is not used or the ignition lock cylinder
is tampered with, the fuel system is disabled and the vehicle
will not start. During normal operation, he SECURITY light
will turn off approximately five seconds after the key is turned to
RUN. If the engine stalls and the SECURITY light flashes,
wait about 10 minutes until the light stops flashing before trying
to restart the engine. Remember to release the key from START as
soon as the engine starts. If the engine does not start after
three tries, the vehicle needs service. If the engine is running and the
SECURITY light comes on, you will be able to restart the engine
if you turn the engine off. However, your Passlock system is not
working properly and must be serviced by your dealer. Your vehicle is not protected by Passlock at this time. You may also want to
check the fuse. See Fuses and Circuit Breakers on page 5-85.
See your dealer for service. In an emergency, call the M
Roadside Assistance Center. See Roadside Assistance Program on
page 7-5.
Testing the Alarm The alarm can be tested by following these steps:
1.
From inside the vehicle, Iower the driver's window and open
the driver's door.
2.
Activate the system by locking the doors with the power door
lock switch while the door is open, or with the remote keyless entry transmitter.
3.
Get out of the vehicle, close the door and wait for the SECURITY light to go out.
4.
Then reach in through the window, unlock the door with the manual
door lock and open the door. This should set off the alarm. When
the alarm is set the power door unlock switch is not operational.
If the alarm does not sound when it should but the headlamps flash, check to see if the horn works. The horn fuse may be blown. To
replace the fuse, see Fuses and Circuit Breakers on page 5-85.
If the alarm does not sound or the headlamps do not flash, the
vehicle should be serviced by your dealer.
Jul 26, 2016 | 2003 Chevrolet TrailBlazer
Whr is my fuel pump reset button on my 2003 grand am? Its security lock, it wont get any fuel. It cranks but wont start. Not getting any fuel. First time ever happening
There is no reset button.
The problem could be the anti-theft system which would knock out the injectors and spark to the plugs.
If the security light is staying on, the problem could be the chip in the key.
Oct 26, 2015 | Cars & Trucks
I just installed a new key switch in my 2006 trailblazer it is a napa part now when I start it it will only run for a few seconds and die ?
That is because of the vehicle theft deterrent system ! Do you have a security light lit on the instrument cluster ?
The Passlock?"¢ System is provided in order to prevent vehicle theft if the ignition lock cylinder is forced to rotate or the ignition switch is operated while separated from the ignition lock cylinder case. If starting is attempted without authorization from the Passlock?"¢ System, the powertrain control module (PCM) will disable engine starting. Start disable may be in the form of fuel disable or starter disable, depending on engine application.
The components of the Passlock?"¢ System are as follows:
The ignition lock cylinder and key
The ignition lock cylinder case, including the Passlock?"¢ sensor
The ignition switch
The security indicator on the instrument cluster
Ignition Lock Cylinder Case, Including the Passlock?"¢ Sensor
The ignition lock cylinder fits inside the ignition lock cylinder case and operates the ignition switch when turned by a key with the proper mechanical cut. When the ignition key is used to turn the ignition lock cylinder to crank, start, a magnet on the lock cylinder passes close to the Passlock?"¢ sensor within the ignition lock cylinder case. The magnet activates the security hall effect sensor in the Passlock?"¢ sensor which completes a circuit from the security sensor signal circuit through a resistor to the security sensor low reference circuit. The resistance value will vary from vehicle to vehicle.
If a magnet from outside of the ignition lock cylinder case is used to attempt to steal the vehicle, the tamper hall effect sensor will be activated. This completes a circuit from the security sensor signal circuit through a tamper resistor to the security sensor low reference circuit bypassing the security resistor. If the ignition switch is forced to rotate without the correct key, or if the ignition lock cylinder is removed by force, the Passlock?"¢ sensor will be damaged and will not operate.
Feb 22, 2015 | 2006 Chevrolet Trailblazer
Why won't my car start when the security lock is shown on dash panel
That symbol indicates the security system is activated and the engine is locked out, if you believe this to be in error you will need the system scanned to find out what part is causing the system to lock you out.
Nov 02, 2012 | Cars & Trucks
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What...
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 12, 2011 | Chevrolet TrailBlazer Cars & Trucks
My trail blazer 2006 wont start and it has a light on of a car with a lock what does this mean heeelp please as soon as possible emergency
You have now experienced GM's terrible anti theft security system. These systems are known for failing and will cost you an arm and a leg to fix. Anywhere from $350 - $700 plus labor. Most mechanics wont even touch these "PASSkey" security systems.You'll have to go to a Dealer mechanic. The good news is that you can bypass these systems permanently. And you're vehicle is one of these lucky ones that CAN be bypassed. This link should help you find what you need and help inform you of how this system works.
http://vatspasslockpasskeysecurityhelp.yolasite.com/ TRAILBLAZER 2002 2003 2004 2005 2006 2007 2008 Effected by Passlock/PASSkey Failure. tayjoejoe_17.jpg
Jul 11, 2011 | 2006 Chevrolet Trailblazer
2000 Alero - Internal Security system malfunctioning. Sometimes (randomly) when I try to start the car it will not start and the red "security:" light flashes. I have to wait 10 minutes while the key is in...
• The lock cylinder
Passlock™ Lock Cylinder
The Passlock™ lock cylinder is a locking cylinder that turns a rotating magnet past a stationary hall effect sensor. This action creates the Passlock™ cylinder data. The Passlock™ cylinder data is sent to the Body Control Module (BCM). The Passlock™ lock cylinder is interfaced with the BCM via a 3-wire connection:
• Power
• Ground
• Data
Powertrain Control Module (PCM)
The Powertrain Control Module (PCM) is located on the lower left side of the instrument panel.
The PCM communicates with the Body Control Module (BCM) via serial data over the class 2 serial data bus, CKT 1807. When the BCM determines a passed theft condition, the BCM sends a coded password to the PCM. When the PCM receives the correct password, the PCM enables the fuel injection system, allowing the vehicle to operate correctly. The PCM may allow the car to start and quickly stall during a failed theft condition.
The following conditions may cause the PCM to enter a tamper mode:
• A bad timing cycle
• An incorrect password
If the BCM does not receive a password within a preset time window, the BCM will enter a short tamper mode. During this mode, the PCM will not allow the car to operate for 4 seconds.
If the password is incorrect, the PCM will enter the long tamper mode. In the long tamper mode, the following actions will occur:
• The THEFT SYSTEM indicator will flash.
• The fuel injectors will be shut off for approximately 10 minutes.
Although the vehicle may start, the engine will quickly stall due to a fuel cut-off.
In the event of an open in the serial data communication between the BCM and the PCM, the following actions occur:
• The PCM will become fail-enabled if the car has already passed theft for that ignition cycle (i.e. the engine is running).
• The PCM may set the diagnostic trouble codes (DTC).
• The THEFT SYSTEM indicator will light continuously.
• The PCM will become fail-enabled for future ignition cycles.
If a failure occurs in serial data before the ignition cycle, while the PCM is not fail-enabled, the PCM will never receive a valid password in order to enable the continued use of the fuel injectors.
Your best bet , take to a qualified repair shop .
DTC B2947 Security System Sensor Power CKT Low
DTC B2948 Security System Sensor Power CKT High
DTC B2957 Security System Sensor Data Circuit Low
DTC B2958 Security System Sensor Data Circuit High
DTC B2960 Sec Sys Sensor Data Incorrect but Valid
DTC B3031 Security System Controller in Learn Mode
DTC B3033 Security System Indicates Tamper
Aug 12, 2017 | 2002 Oldsmobile Alero
With my 1997 Chevrolet Lumina LS I rebuilt the engine won't start this engine did start beflore I took it out to rebuild but now it don't start and everything is either new or tests good, I think the theft...
your going to need a lock smith to check the ignition system for you, you may need to reprogramme your keys, you can key around the security by by passing th system altogether by running hot wires to a button{ like new cars that start with pressing a button} or a key key switch.
Jul 31, 2009 | 1997 Chevrolet Lumina
Vehicle Parts & Accessories Logo
89 people viewed this question
Top Infiniti Vehicle Parts & Accessories Experts
advance tire and...
Level 1 Expert
Bill Boyd
Tom Chichester
Are you an Infiniti Vehicle Part and Accessory Expert? Answer questions, earn points and help others
