Question about GE Spacemaker JVM1640SJ Microwave Oven
Everything works but it won't heat up - GE Spacemaker JVM1640SJ Microwave Oven
  • GE Master
  • 17,130 Answers
Fault can be from the magnetron, the main capacitor, the door latch contacts , the controller unit or the transformer.
You must use a logic to check from the fuse to the magnetron to the capacitor .Look for short only after checking if there is no residueal high voltage or you will end up damaging the meter.
If high voltage is present during the microwave cycle then the magnetron can be defective.
Please also check for the temperature cut off mounted on the walls of the chamber.
Posted on Sep 12, 2010
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
Jun 05, 2013 | Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
I have the danby designer Mod DMW162W-ORT that won`t heat at all but everything else works. Hums a bit louder but will not warm.
The Magnetron in your unit is no longer resonating properly. The Magnetron produces the microwave frequencies and when it resonates properly, it will provide the excitation to heat your item(s). As well, the diode that accompanies the magnetron needs to be replaced as well. Should it be under warranty, take it back. Out of warranty? Have an appliance tech repair it (usually around $175) or get a new microwave.
This is typical for most microwaves. No such thing as quality any more.
Apr 12, 2011 | Danby Microwave Ovens
GE MICROWARE WON,T HEAT UP
Likely problem: Blown magnetron. On microwaves, this can generally go dead, usually with a popping sound. Solution: A: Call an appliance repairman to replace the magnetron in the device, or B: buy a new microwave. Depending on how much you paid for it, you might be getting a better deal on either end.
Jun 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
324 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
