Question about RCA Lands Phones
RCA 900 MHz Accessory Handset- H5400RE3 for 4-line systems 25413RE3, 25414RE3 & 25415RE3
How do you register the cordless phone? We throw away the box and instructions by accident, when a car came thru our building.
Thanks
Donna75603,
Go near the base of the corded phone to register your cordless phone. Press "menu" on your cordless phone and press arrow key till you see "Registration". Press "Select" key. The sreen will show "Yes" and "No" sign. Press arrow key once to select "Yes" then press "Select" key. The sreeen will show "Registerring.." , at this time press "Page" key on the corded or base phone and hold it for a few seconds until you hear a beeping sound. This is the sign the the phones are syncronized. You can now use your cordless phone.
Jun
Brooklyn
Posted on Jan 25, 2010
How do i register my cordless phone?
Posted on May 28, 2009
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
Tip
Sir, what is wrong with my vtech cordless phones, im always getting this...
If you're having problems with clicking, like the edges are hard to click, or the screen in general is hard to click, the following is how to remedy it.
Tools:
  • Torx T6 screw driver
  • Small needle
Steps to follow:
  • Take off back cover
  • Locate red sticker (water detection sticker)
  • There is a t6 screw under the sticker and directly across from it
  • The problem is that sometimes these screws are too tight
  • Start by loosening the exposed screw a tiny bit, then check the clicking on the screen - if this doesn't work, loosen a little more. If the clicking still doesn't work correctly, move on to next step
  • Remove the sticker with the small needle (this will not void your warranty) - loosen the screw as you did with the first screw -
  • Check the clicking to see if it works better - if not loosen screws more
  • Replace the sticker
  • Replace back cover
Your screen should now be clicking better. Thanks
on Aug 03, 2010 | Panasonic 900 MHz Cordless Phone
I have purchased a SL82318 Handset. I have a SL82318 system, with all three original handsets working perfectly. This fourth handset displays: "Connecting..." and nothing else. According to...
*331734#Menu Select on the handset should de-register that handset from the old base, then you can register it to the base as per the manual (put it in the base and hold down the handset locator button for 4 seconds)
Jan 04, 2011 | Vtech SL80108 1.9 GHz 1-Line Cordless...
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Thanx
Jul 21, 2010 | Uniden Cordless Phone
I have a tcx905s handset that will not register to my tru9496 base. Uniden claimed that 905s units will work with this base. However, they said that refurbished units will not work. Is this true?
Not sure about the refurbish issue...but have you tried to de-register the handset by holding down the end key and the # key, then placing on the main base unit to register with your system.
Sep 25, 2009 | Uniden TCX905 Cordless Accessory Handset...
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
Handset Replacement
Did you get a replacement for your handset?
Dec 27, 2008 | Uniden Cordless Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Echo
MOVE IT AWAY, AS FAR AS POSSIBLE, FROM OTHER ELECTRIC DEVICES
Feb 04, 2008 | GE 25932 Cordless Phone
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
Lands Phones Logo
794 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
