Question about Pioneer Car Audio & Video
Sir, Can you give me any information on the wiring for the Pioneer DEH-M6156zh CD player? I want to install it in my Camper Van. Thank you, Robert M. Love
KaeZoo
  • 156 Answers
SOURCE: Wiring color codes for pioneer deh-425
Yellow: battery power Red: switched power Black: ground White: left front speaker Gray: right front speaker Green: left rear speaker Violet: right rear speaker Wires with stripes are the negative speaker leads.
Posted on Mar 07, 2007
simplemitch
  • 752 Answers
SOURCE: Have Pioneer DEH 1900MP CD
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
the clock display you wish to set.
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
You can turn the clock display on or off.
! Even when the sources are off, the clock
display appears on the display.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Operating this unit
12 En
Posted on Aug 05, 2008
Fame_Guru
  • 483 Answers
SOURCE: need wiring diagram
here you go ::
http://4x4icon.com/crossfire/basslink/harman_kardan_drive_play_wiring10.gif
Thanks
Fame !
Posted on May 09, 2009
XSdB
  • 80 Answers
SOURCE: need a wire diagram for pioneer DEH-1100 super tuner
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Posted on Jun 12, 2009
  • 9 Answers
SOURCE: I need the wiring diagram for the Pioneer CD
Red= acc 12v
Yellow = constand 12v
black = ground
blue/white = remote turn 12v out.
purple pairs are the Right rear speaker
Grey pairs are the front right speaker
white pairs are the front left speaker
green pairs are the left rear speaker
orange white is the dimmer.
Posted on Jun 29, 2009
Installation wiring diagram for pioneer deh 1700
here is the link for the installation manual and user manual:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1700.Support
see the installation manual page 1 far right side for wiring diagram is listed as other manual
Cheers!
Nov 17, 2009 | Pioneer DEH-1700 CD Player
Wiring problem
Here is the support page for the manula and the installation instructions. Solved?
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-P3500?tab=D
Dec 30, 2008 | Pioneer DEH-P3500 CD Player
Wire diagram
www.pioneerusa.com
red-12 volt ignition
yellow -12 volt regardless of ignition switch position
white-left front speaker +
white /black stripe speaker -
gray- right front spe +
gray/stripe right spe -
green-left rear spe +
green/stripe left rear spe -
purple- right rear +
purple/stripe right rear -
if this helps you please give a good rating- thank you
Aug 09, 2008 | Pioneer DEH-1600 CD Player
Automatic electric arial wiring
To my knowledge, Pioneer uses the blue wire to provide the +12 to power antennas.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Car Audio & Video
Wiring/Installation of Pioneer CD Player
You need to get an installation kit that also has the universal wiring harness to connect to the factory harness in the car. That way you only need to match the wire colors of the Pioneer harness to the wire colors of the universal harness and made good connections and insulate those connections. Then the Pioneer harness plugs into the Pioneer radio and the universal harness plugs into the factory harness in the car.
Let me know if this helps, or if you need more help.
Dave
Jul 06, 2008 | Car Audio & Video
Car stereo
Goto www.installdr.com They have all wire diagrams for all cars. Next time, don't cut the car harness. Go get a snap in wire harness.
Jun 15, 2008 | Pioneer DEH-P2000 CD Player
Pioneer deh 2300
buy a build ur own connectr at radio shack use all the pins then just figure out what wire goes to what
Mar 29, 2008 | Pioneer DEH-2300 CD Player
Wiring problem
The installation and owner's manual may be found here:
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-P350?tab=D
Mar 23, 2008 | Pioneer DEH-P350 CD Player
No power to my player
A Pioneer DEH-P2500 power wiring would include:
* Black - chassis/body ground (GND)
* Yellow - always on B+12 such as the + terminal of the battery;
* Red - switched on B+12 such as the ACC terminal of the IGN switch.
Mar 21, 2008 | Pioneer DEH-P2500 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Car Audio & Video Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
