Question about Texas Instruments TI-84 Plus Calculator
I can't seem to get the correct batteries for my Texas Instruments TI-84 Plus Calculator...can any AAA 1.5v battery use in it? I tried some duracell of that same type and they didn't work
  • Texas Instru... Master
  • 7,993 Answers
All the AAA batteries whether non-rechargeable alkaline (Duracell, Energizer, Rayovac, Varta, Maxell, Panasonic, Sony, Sanyo, etc) will do. Each of these types of batteries has a voltage of 1.5V
You can also use rechargeable NiCd (Nickel-Cadmium) or NiMH (Nickel-Metal Hydride) 1.2V AAA. However TI Instruments say that under no circumstances should one use rechargeable batteries.
The trivial possible reasons why the the Duracell did not work are:
  1. The lot was depleted.--Replace with fresh ones
  2. The electrical terminals may be broken or dirty or corroded by a previous acid leak.---Clean the terminal even if they appear shiny. The eraser tip of a pencil should be good to rub away any dirt.
  3. You did not place them correctly: Wrong polarity. This is a very common mistake (I know from my own experience).
Posted on Sep 12, 2010
Where is backup battery on ti-84
Open the battery compartment. Above the four AAA batteries you should see a small screw. Unscrew that to uncover the backup battery.
Jun 05, 2014 | Texas Instruments TI-83 Plus Calculator
Is there areset button my keys are frozen
Unfortunately, you can only access RESET from within the menus of the calculator. You will have to remove all of the batteries and let the system naturally reset. The TI-84 Plus uses five batteries: four AAA alkaline batteries and one SR44SW or 303 silver oxide backup battery. The silver oxide battery provides auxiliary power to retain memory while you replace the AAA batteries. Re-install the batteries and reprogram your functions.
Oct 23, 2011 | Texas Instruments TI-84 Plus Silver...
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
Changed the AAA batteries but screen remains blank
Check for corrsion on battery terminals AND check batteries are in the correct direction.
Jan 24, 2010 | Texas Instruments TI-84 Plus Silver...
Texas instruments TI-83 Plus won't turn on. I have replaced the AAA batteries.
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press [2nd] key and release it.
Press and HOLD [UpArrow] till it darkens enough.
If that does not solve the problem here is what the TI Knowledge base has to say. Please read till the end. I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
If that does not solve the problem, you should contact Texas Instruments at ti-cares@ti.com or www.ti.com/calc.
Nov 09, 2009 | Texas Instruments TI-83 Plus Calculator
Press
Have you tried to reset the calculator?
From page 671 of the TI-84 Guidebook:
To reset the calculator:
1) Remove all AAA batteries
2) Hold down the On button for 10 seconds
3) Reinsert AAA batteries
4) Turn the calculator back on.
Note: When you reset your graphing calculator, the contrast sometimes changes.
Nov 05, 2009 | Texas Instruments TI-84 Plus Silver...
I accidentally pressed down for too long on my ti-84 plus calculator and i think it locked itself. how can i turn it back on? I NEED it for school!
From TI FAQs:
What troubleshooting can I try if the TI graphing calculator will not turn on?
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Aug 24, 2009 | Texas Instruments TI-84 Plus Calculator
Frozen ti 84 plus silver edition
Ther is no reset button. You have to take the batteries out.
Take the AAA batteries out and take the back up battery out...located in a little door with a screw just above the AAA batteries. Leave the batteries out for about 8 hours. This is how you reset a TI graphing calculator.
Aug 18, 2009 | Texas Instruments TI-84 Plus Silver...
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
111 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
