Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Won't power up
I have the same problem with my XM2Go. The screen is blank. I ordered a replacement battery but it still doesn't work. It will try power up but it dies down in seconds.
I could really use some help.
Vince
Greetings,
It sounds like your unit has a short in it. Unfortunatly if you have replaced the battery there is not much else you can do. You could try prying it apart to see if there are any loose connections, but doing so might further damage the unit. Have you tried contacting pioneers customer service? 1.800.228.7221
Good luck,
-WN
Posted on May 14, 2008
  • 796 Answers
Have you tried resetting the device....
may be there is some problem in the power circuit
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
My dell Inspiron mini won't turn on. I have
disconnectt the adapter+battery and HOLD the power button by 30 seconds. in order to eliminate any EDS, in the power. And try again.
However if the problem persist, test very well the adapter+battery and p.supply in the c.board of computer for some cold solder contact, etc God bless you
May 21, 2013 | Computers & Internet
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi myfi xm2go
Replace the battery. Your Myfi will not work without it -- even if it is plugged into the charger.
Mar 03, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
BRAND NEW BUT NO DISPLAY
I also had the white screen / blank screen problem on my Inno today.  I powered the unit off, removed it from the home cradle, and then popped out the battery for about 15 seconds and put it back in.  This fixed the problem.
Sep 13, 2008 | Pioneer XM2go Inno Satellite Radio...
Pioneer xm2go power surge
Vince
Mar 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
106 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
