Question about Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8103D 1000 watt issues
I blew a speaker not too long ago. I replaced the speaker yesterday. Plugged it into the Amp. Turned on the stereo and noticed that the speaker wasn't working. I looked at the Amp and the Power light is flashing on and off and on and off.... Did I ruin my Amp? I checked all the fuses... they're all good. What to do now? Please help
  • Chief714 May 14, 2008
    How can I repair it? The old speakers did fail, so I picked up a new one, but the red power light just flickers.
  • JerseyRJ May 09, 2009
    i have the same amp and the sub was kicking in and out the fuse went, so i replaced it and now no sound, power light on, wires are good and works on an old amp, volts are good, amp not putting out **** any suggestions
Apparently it won't let me log in. Anyhow... I'm pushing voltage. The light is flashing, not flickering. How can I replace the transistors?
Posted on May 15, 2008
It is a "flashing" not a flickering and it is pushing voltage. what next?
  • 631 Answers
The speaker may have shorted and caused the output transistors in the amp to fail. This is fairly common. It can be repaired.
Posted on May 14, 2008
  • Perry Babin May 15, 2008
    Flickering is different than flashing. Before you do anything, confirm that you have at least 11v DC on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amp when measuring the voltage.
I need to know the wattege of a kenwood kac -624
The KAC-624 is a 40 watt x2 @ 4 ohm RMS amp. 55 watt x2 @ 2ohm. 110 watt x 1 Bridged I assume at 4 ohm. Manual does not specify. It can run 2 ohm in stereo mode but is unclear on mono impedance requirement. It can run 4 ohm mono at 110 watt but at 2 ohm?
Dec 12, 2011 | Kenwood Car Audio & Video
My light on my Kenwood Kac-8103D amp is constantly on red and nothing is coming out? How do I fix this
Check your fuse. Also make sure all your wiring and terminals are correct and not loose.
Dec 11, 2011 | Kenwood KAC-8103D Car Audio Amplifier
I need an appropriate speaker for my kenwood amplifier kac-5202
This amp is stable down to 4 ohms bridged at 120 Watts or 2 ohms stereo at 60 Watts X 2. If you are going with the bridged mono hookup just make sure the impedance of your subwoofer is no less than 4 ohms. A good rule of thumb is to be at least double of what your amps rated output power is. So if your amp can put out 120 Watts into 4 ohms then get at least a 240 watt subwoofer.
Do not exceed the rated load for your amp, you will damage it. Here is the datasheet for your amplifier
http://manual.kenwood.com/files/B64-3031-00_En.pdf
Jun 12, 2011 | Kenwood KAC-5202 Car Amp
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
I have one 10in. Kicker L7. and a Kenwood KAC-929 1000 watt amp. What are all the wires i should buy that can make this setup run?
Need an amp kit up to 1000 watts, speaker wire. Amp kits have most of the wires needed such as, power, ground, and remote wire. As well as all the connectors needed.
Sep 22, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
The sound will no come out the speakers
Does the unit have power? Check the RCAs from the stereo; are they connected. Check the speaker wires; are they connected?
Sep 16, 2010 | Kenwood KAC-8103D Car Audio Amplifier
I have two Kicker dvc cvr's 12's and I want to hook them up to a Kenwood KAC-520 1000 watt amp. Whats the best wiring to wire these?
The best thing to do would be to get an amp installation kit, at an auto stereo store or Wal-Mart automotive department. It will have the wiring and connects that you'll need to wire everything up.
May 19, 2010 | Car Audio & Video
Can u fix a blew amp
yeahhh but you would have to send it in and hope its under warrenty. best bet do waht all the other jackasses do. sell that **** on craigslist
Apr 08, 2009 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Transistors
If it's only 2 months old, it should be under warranty. Have you tried to get it repaired under warranty?
Any car audio repair shop should be able to repair it.
If you want to repair it yourself, it's possible but you'd need basic test equipment and soldering/desoldering tools.
The following page shows you the basics for amp repair. Your amp is somewhat different than the one shown but the troubleshooting/repair procedure would be similar.
Basic Amp Repair Primer
May 16, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood KAC-8103D Car Audio Amplifier Logo
738 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
