Air conditioner running but not cooling air outside unit is not running
  • 144 Answers
Check the power is breaker tripped at outdoor unit aswell could be blown fuse are you getting power to contactor has the 24volt coil pushed the contactor in if not then the problem is inside why isnt it calling for the outdoor unit to come on check your float switch in the drain pan it will prevent outdoor unit from coming on make sure their is no water in the pan
Posted on Sep 12, 2010
My air conditioner froze up. We turned it off over night and cleaned the evaporator and condenser now it doesn't cool at all.
is the outside unit running? may have got something wet have someone turn it to cool while your at outside unit see if it's starting up. one line should be warm the other cool.
Jun 18, 2014 | Goodman Heating & Cooling
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
The furnace is running but there is no cool air. I change my filters every month and I flushed out the water lines last month.
flushing out water lines do you mean condensate line coming off the furnace that drain to the outside. is the condensing unit outside running when u have it in cooling mode. by condensing unit I mean the unit outside that has lines that run to the inside. does that turn on when u have it in cooling. the unit outside have two components that should turn on the outdoor condenser fan and a compressor.
Aug 21, 2011 | Ruud UAKA060 Air Conditioner
My air conditioner starts blowing like a fan before my apartment is cooled off, why does it kick off and on like this?
When you first turn it on the fan runs and after a few minutes the outside unit comes on, once the outside unit comes on it take time for it to cool the coils which cool the house, And a/c does not really cool the air,It removes the heat that is in the air.
Aug 04, 2010 | Kenmore Heating & Cooling
Goodman A/C won't cool
Fan motor or capacitor has gone out. Running the unit with the motor not running can cause damage to your compressor
May 01, 2010 | Goodman CKL24AR24 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Outside makes loud noise
I would take a very close look at every solder joint there is between the inside unit and the outside. If you observe oil at any point it indicates a leak at that point. That is an expensive price for what you say was done. Check your invoice for the amount of refrigerant they or he added to the system. Compare it with the amount stated on the outside unit nameplate. Check for frost on the suction (big line) by the outside unit. If there is frost your coil is frozen up. If this is the case turn the fan on and the cooling off. Allow it to run in this manor for about an hour to defrost the A coil. Then return to the cooling mode.
Jun 15, 2008 | Weather King 10AJA4201AH Air Conditioner
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
