Question about E-Machines eMachines Desktop PC
When i turn the computer on it says windows root 32 is corrupt or missing please reinstall but i cant get it to reinstall it the install menu does not pop up
    Scholar:
  • 128 Answers
You need to re-install it using your disc not when your on Windows enable for it to install. Here are the steps to install Windows back in your system.
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows .
  6. Follow the instructions on the screen to complete the Windows Setup.
Posted on Sep 12, 2010
Reinstall windows root system 32 hal.dll
Do a start up repair.
Insert your Windows Operating System disc in the DVD. Reboot your computer and press any key when you see the phrase "Press Any Key to Boot in CD".
Select the start up repair and it should work after the loading process.
I hope this helps.
Carlo
Jan 23, 2013 | Dell Inspiron Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Acer Aspire one D250. Upon starting up it says: windows root sys32.hll.dl is missing or corrupt, please install this file. Then when I hit enter it says: disk error has occurred press ctrl alt del to...
Your Windows installation has become corrupted.
You need to repair the Windows Installation with the aid of the Original Windows Disk. It is a tricky business, a computer technician will be able to do it for you if you get stuck.
Thanks
damnor01
Apr 13, 2011 | Intel Computers & Internet
My sylvania laptop is stating"
okay when u installed windows okay it corrupted a file clean ur disk sometimes when the disk is dirty it wont copy all the info from the disk if its not that check if u got a 32 bit or 64 bit windows verision sometime s laptops are 32 bit or 64 bit
Apr 11, 2011 | Sylvania G-Netbook
The laptop shows windows system 32 configuration file corrupt error how to run laptop?
Hi
Windows system 32 file is part of the operating system and when it is corrupted, you cannot boot up your computer. I suggest if you had a systems back files, use it to recover the missing file. Just load the back up disk CD/DVD into the CDROM, boot up your computer and run it to CDROM and option will display and choose the repair.
If don't have the systems back up disk. Only solution is to reinstall or repair your operating system.
For reinstalling and repairing, insert the OS installer CD in your CDROM and boot up your computer and run the repair or reinstallation process. Follow the procedure.
Jan 13, 2011 | Lenovo IdeaPad S10 - 42312BU Notebook
Windows root system32 ntoskrnl.exe missing or corrupt can you reinstall it without cd?
you can install id using a USB drive.
make your USB drive bootable and then copy the files from any other computer .
Google out on how to make the USB bootbale.
May 19, 2010 | Microsoft Windows XP Professional
I DID A FORMATT FOR MY LAPTOP , BUT THERE IS A
The CD you are using to install the operating system had corrupted .try using another recovery disk.this will fix the issue....
May 10, 2009 | Toshiba Qosmio G35-AV600 Notebook
How do I...
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Miscellaneous corruption
Corrupt boot.ini file.
Missing boot.ini file.
Missing or corrupt ntoskrnl.exe file.
Windows NT installed on a partition bigger then 7.8GB
Corrupted hard disk drive or severely corrupted Windows.
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
System recovery options
reinstall your operating system
but you will gonna lose everything you have on it
you can log on to www.windowsreinstall.com
for screenshots and info available to reinstall windows.
Jun 23, 2008 | HP Pavilion ze2000 Notebook
E-Machines eMachines Desktop PC Logo
53 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
