Question about Power Acoustik LT-980/2 Car Audio Amplifier
I would like to know how watts or rms is it - Power Acoustik LT-980/2 Car Audio Amplifier
    Problem Solver:
  • 9 Answers
220 Watts X 2 @ 4 Ohm RMS
• 280 Watts X 2 @ 2 Ohm RMS
• 980 Watts X 1 Bridged Output
• 560 Watts X @ Mono RMS
Posted on Oct 20, 2010
Whats the RMS Watts on a Performance Teknique ICBM 5910 I know it has 1500w peak but I'd like to know the rms watts on the subwoofer
Personally, I would not put more than 500 RMS total to that sub. 300-400 RMS is more like it.
Jan 05, 2014 | Car Audio & Video
Watts rms?
It is the root mean square (abbreviated RMS or rms), roughly 0.707 of the peak wattage of an AC source. Crutchfield lists it at >power range: 2-110 watts RMS (450 watts peak power)
Sep 16, 2013 | Kenwood KFC-6986 Coaxial Car Speaker
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
How many watts does this amp put out
50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
150 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
Feb 19, 2012 | Alpine MRP-M650 Car Audio Amplifier
Want to know how many wattes there is?
  • 130 watts RMS x 2 at 4 ohms
  • 180 watts RMS x 2 at 2 ohms
  • 360 watts RMS in bridged mode
Here is a good review of it:
http://caraudiomag.com/articles/jensen-jxp-720-car-stereo-amplifier
Not a great amp for the money really.
Feb 06, 2011 | Jensen JXP720 Car Audio Amplifier
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
How many watts is it?
KA3 offers 125 watts RMS at 4 ohms, 200 watts RMS at 2 ohms, and 250 watts at 1 ohm. The high-current section offers 50 and 75 watts RMS at 4 and 2 ohms, respectively
Sep 30, 2009 | Jensen KA3 Car Audio Amplifier
Infinity 1211a @ 2 Ohms
Hello monkey_flea, Your subs will share the amp output. And if you are not careful, you'll end up blowing them. The amp puts out 1300 watts RMS at 2ohms, the subs have an RMS power range of from 75-350 watts, and you'll be driving them with 650 watts each. A better power match would be to series the subs to present an 8ohm final load. This will reduce the output power to a level the subs can handle. Or you could buy 2 more 12.1's and connect them series-parallel for a 4ohm load and each sub would still be getting 325 watts RMS, just about the maximum they are rated to handle. Hope this helps.
Jun 03, 2009 | Infinity Reference 1211a Car Audio...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Power Acoustik LT-980/2 Car Audio Amplifier Logo
173 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
