Question about Midway Home Entertainment Rise & Fall: Civilizations At War for Windows
Unable to locate file, the data path appears to be incorrect, please check your data path
ERROR Unable to open NSF file
Verify that the nsf file is present in the path specified. The TSV file row for that particular user can be edited to enter the correct path to the mail file, and then attempt the migration again.
In most cases, the mailserver name is incorrect, and changing this value to reflect the correct mailserver that contains the NSF file should resolve the issue. If it useless, there is a good program: Lotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
Apr 18, 2016 | Computers & Internet
Unable to locate file, the data path appears to be incorrect, pleas check your data path After i open the game
The game's installation seems to corrupt. Try re-running the game's setup file and - whenever possible - choose the 'Repair' option ...
Jun 27, 2014 | Midway Home Entertainment Rise & Fall:...
Unable to open Hard disk drive
try running a check disk to check for errors. In windows command prompt type chkdsk C (substitute C for the letter of the drive).
Has anything happened to these drives such as dropping that would cause it to not be readable? What format is the disk FAT or NTFS?
Hit us up at our techie forum:
http://forum.wasatchtechies.com/
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Feb 11, 2014 | Western Digital Computers & Internet
My slcdii file is missing, how do I retrieve it?
Its scl dll file not slc dii.
1. Download, install and run DLLSuite,
2. Click Start Scan button to conduct a full scan for slc.dll as well as corresponding issues
3. Locate to file slc.dll and click More Information. You will reach a web page where you can download slc.dll file.
Tips: Before save slc.dll to its path, please use DLLSuite to create system restore points first as if the file path is incorrect, your system would become unstable, even crash.
4. Click Start, Run and type regsvr32 slc.dll , and then press Enter.
5. Restart your computer
Hope it works for you.
Also use a sytem utility software like ReginOut to avoid such type of errors. It will optimize your PC and fix different operating system errors.
Dec 26, 2011 | E-Machines (T3104) PC Desktop
Unable to open the folder in pendrive
The "Personal Data" folder stores all necessary data for StoreJet elite software use (including elite backup files storage). If you would like to backup files into personal data folder, please refer to the manual to use data-backup function.
(http://www.transcend.com.tw/Support/DLCenter/Manual/StoreJet_elite_EN.pdf).
Please do not manually store other data inside this folder. It might cause the software/system to function abnormally. We suggest user to store data at other different folder/path, and avoid occupying "Personal Data" folder. blackbar_left.jpg Print blackbar_right.jpg
Oct 28, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Sep 25, 2009 | Microsoft Windows XP Home Edition
HP Deskjet F2200 All-in-One SCAN green light flashes but does not scan
Error: “HP Cue Scanning Flow component has encountered a problem and needs to be closed”.
The problem is caused by HP software not installing the file path to the scanner correctly in XP, so if you run a registry cleaner such as RegCure it will delete the file path.
OS: Windows XP.
If you encounter this error message please follow the steps below:
1. Go to registry by clicking on Start/Run then typing in regedit and hitting enter.
2. Go to HKEY_ Local_ Machine\Software\Hewlett-Packard\DigitalImaging\
3. Click on the Digital Imaging Folder and in the Right Hand Side Pane and check if the String Value “ProfileWritePath” is present and Value is set to %APPDATA%\HP\Digital Imaging\Data\Destination
4. If the Sting Value is not present right click and then click on new and then click on String Value Name it as “ProfileWritePath” and then right click on that and click on Modify and make sure that the value is set to “%APPDATA%\HP\Digital Imaging\Data\Destination” and close the registry editor.
5. Then go to My computer C:\Documents and Settings\All Users\Application Data\HP\Digital Imaging\Data and check if the Destination folder is present. If not create a new folder and name it as “Destination”.
6. If you are unable to locate the Application Data folder under All users, click on Tools and then click on Folder Option. In the Folder Options Window click on the View tab and under Hidden Files and Folders make sure that “Show Hidden Files and Folders” is checked and then click on Apply and then click on OK..
7. Then Make sure that the same that the HP\Digital Imaging\Data\Destination folder is present under all user profiles Application Data folder.
8. Run Regcure and after the scan check the file/path errors and tell it to ignore the HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\digitalImaging ProfileWritePath= C:\Documents and Settings\ (whatever your file path to the destination folder is)
Now it should run flwalessly even after you run regcure.
For other registry cleaners I'm sorry but you will have to find out how to tell your cleaner not to delete the erroneous file/path error.
Graham Sept 13th 2009.
Oct 14, 2008 | Office Equipment & Supplies
'unable to save file. the system cannot find the path specified'
Please check the location where the file saved by your Scanner and note down its size.
Also as you mentioned in your next reply, you need to go for check Device manager. Reinstall the drivers.
Let me know if you need further assistance. Don't forget to vote me.
Regards
Ellin
Sep 25, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Error #80004004
The problem is with outlook. Have you activated the product?
"The following appointment cannot be written to Microsoft
Outlook due to error 80004004. The item will be skipped."
This error code indicates that the operation has been aborted during reading
of the pst file. This might be a result of some kind of corruption.
Search for a program called scanpst.exe. This is a small utility included
with Microsoft Outlook which will scan your *.pst file (the file that
contains your personal information) for possible corruption and attempt to
repair it. The default location of the file are as follows:
* Windows XP, NT and 2000:
C:\Program Files\Common Files\System\Mapi\1033\NT\scanpst.exe
* Windows 95, 98, and Me:
C:\Program Files\Common Files\System\Mapi\1033\95\scanpst.exe
Note: C: might need to be replaced with appropriate drive letter.
You will need to run it against the .pst file. If you are unable to locate
the path of the .pst file, do the following:
1. Open Outlook.
2. Click File -> Data File Management
3. This should list all the PST files that are present. Click Open Folder
and you should find the storage path of your *.pst file.
Good luck and if theres anything else let me know!
Feb 19, 2008 | HP iPAQ RZ1710 Pocket PC
Recover tally data
Dear Sir/Madam,
I am getting the following error,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Please give me a solution to get my data and I am using Tally7.2 version...
Thanks & Regards,
S.Prasada Rao
Sep 10, 2007 | Tally T2250 Matrix Printer
Midway Home Entertainment Rise & Fall: Civilizations At War for Windows Logo
832 people viewed this question
Top Midway Home Entertainment Video Game Consoles & Games Experts
Tony
jasbo
jasbo
richie46
Are you a Midway Home Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
