I just replaced the lamp on my zenith 52" but it still seems a little dark and not crisp. Could there be another problem?
  • 1,476 Answers
Momma212,
Check to make sure that you inserted the lamp assembly properly and it is not skewed or misaligned.
Thanks for using FixYa.
hardrocko
Posted on Sep 12, 2010
Zenith 52" LCD. When the lamp goes out does the sound go out also? Tv wont turn on and the power and lamp light flash red. no sound.
Has Lamp been replaced? Also if Blaster board is bad Lamp will not turn on also CK Fan behind Lamp If it is not running Set will not turn on For Parts Try Encompass 1-800-639-3328 or look on line www.Encompass Parts, Also Look on E-Bay for Lamp and Blaster Board I found Lamp fot mine for 85.00 and blaster board for 55.00Type in Model number it will be on back of your TV.
Nov 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Hitatchi 52" rear projection TV has blue spot in middle of screen
Hello :
I suggest u retrace you the steps u took to replace your lamp make sure no foriegn objects got on the prism where the light shines throung the optics engine, if you remove the lamp compartment througly. If you had a perfect picture prior to replacing the lamp, then retracing your steps you might find something that does not belone. One final note: Did you purchase the right lamp 120watts anything higher than this wattage could damage your optics engine. I suggest never vacuuming the compartment because particals fly around from the suction and could get on the glass of the color wheel asembly.
Sep 25, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith d52wlcd 52 inch rear proj. overheating symbol appears within 2 hours of operation
some solutions
1 clean fan
2 lamp reaching end of life. replace
3 seak profetional help
Oct 04, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
Reset Lamp
Look in your owners mannel if you still have it,it should tell you lamp reset code.
Aug 20, 2008 | Zenith D52WLCD 52" Rear Projection...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith model #m52w56lcd tv?
For a really good step by step with pictures guide to replace it go to
http://www.fixyourdlp.com/blog/?p=34
For a good place to purchase the lamp go to http://www.discount-merchant.com/Original-Zenith-Projection-LCD-TV-Replacement-Lamp-p
/zenith_m52w56lcd_lamp.htm
I have found they have the best price on these replacement lamps. You might also check Ebay.
Feb 21, 2008 | Zenith D52WLCD 52" Rear Projection...
Changed Lamp, But not as bright as before!!
Just had that problem wrong lamp used orignal lamp fixed problem
How to reset lamp timer
press and hold the "enter" button on the TV, the press and hold the "menu" button on the zenith remote-- after several seconds of holding both buttons the option of re-setting the lamp came up. Hope this helps
Jan 18, 2008 | Zenith D52WLCD 52" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
