Question about Haier HBCN05FVS Wine Cooler
NOT GETTING COLD ENOUGH, BEER AND COLA ONLY GET TO A 45 DEGREEE F.
Freezer not getting cold enough (20-25) and fridge at 45-50 and running all the time
Check and clean the coils. If that doesn't work, then the Freon needs recharged.
Jan 23, 2014 | Kenmore Refrigerators
Krups b100 does not get cold enough. How do i fix this
Maybe the beer inside is cold enough to drink, but the green led that indicates it's ok, doesn't light on. So the thermostat may be not operating well or the ambient temperature is too hot. My beertender B100 is operating without turning compressor off. The compressor never stops operating... even when external temperature is under 26 C... but the beer temperature is ok.
Oct 04, 2013 | Krups VB2158001K BEERTENDER B100
What temperature should beer be at for drinking?
Each style of beer has a certain guideline for suggested drinking temperatures. Here are a few:
- Wheat beer and pale lager= 45-50F
- Pale ales and amber/dark lagers= 50-55F
- Dark ales, porters, stouts= 55-60F
- Fruit beers= 40-50F
Feb 03, 2013 | Wine & Spirits
We have a small Daewoo fridge my husband uses in the garage for his beer and it is not getting cold enough It is about 135 litres and even on maximum the freezer part has no ice in it
Small fridge not cold enough causes
(1.) Restriction in the freon dryer / capilary tube
(2.) Loss of freon / coolant due to pin hole type leak
This also does not rule out the compressor as a suspect. Do you know if the compressor stays running for an extended time? If not there can be a problem with the (3) PTC relay, (4) the thermal overload or the (5)run capacitor.
If the compressor is running for an extended time but just not reaching the correct temp and then automatically cycling off (6) the temp control can also be the problem.
And finally the last possible cause can be a (7) dragging compressor rotor i.e. not running full speed.
There is not and instant "this is the problem" solution for a not cold enough symptom unless this is a frost free unit... then we need to discuss defrosting problems.
Thanks for using FixYa.
Kelly
Mar 15, 2010 | Daewoo Refrigerators
My coca cola refrigerator has power but it's not cold
Its either your gas pipes has a leakage or no gas or you gotta replace your drier.its a blue round vessel near your canister
Dec 29, 2009 | Montgomery Ward Coca-Cola® Beverage Cooler
I have a Sanyo kegerator that will not cool enough. I have set the thermostat as cold as it will go and it will only go down to about 42 degrees. What can I look for?
Drop thae stat it's a screw on the left side that controls temp.Don't rush this you don't wnt to freeze your beer. 1,5 turns to the left will take you down to ice cold beer.
Nov 18, 2008 | Sanyo Refrigerators
Beer not getting cold
Try cleaning the coolers condenser core.
Jul 06, 2017 | Frigidaire PLKU1267DS Stainless Steel...
Cooler`s Spare Parts
Coca Cola does not manufacture these coolers. They are manufactured by another company for Coca Cola. Model number MT45 is a "Beverage Air" product.
Some parts for these units can be ordered through a company called "Case Parts" that are on the internet.
Jul 30, 2008 | Beverage-Air Refrigerators
Beer box tempature control not getting cold enough to temp. specs
check the vendilation condition/temprature out of the freezer
Nov 17, 2007 | True TD-95-38-LT Beverage Cooler
Haier beer dispenser model HBF05E
Either its not getting cold enough to shut off or your thermostate isnt working.. thats the only thing that cycles it.
Aug 27, 2007 | Haier (HBF05EAVS) Beverage Dispenser
Haier HBCN05FVS Wine Cooler Logo
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
