Question about Refrigerators
Can you recommend a freezer that will work properly in a garage or barn at -30C ?
  • 101 Answers
None cant be in rooms colder then 45f to 100f
Posted on Sep 12, 2010
Freezer defrosts all the time
The defrost timer is faulty
Jan 16, 2014 | Refrigerators
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
I have a new frig that I keep in my garage to keep extra food and drinks in. Since the weather turned cold, the freezer is not working properly. The frig still seems to working great. Can you help with...
If the ambient temp is below 52 degrees the unit will not work properly throught the cycles you will need to get what is call a garage kit to install in the unit.
Dec 25, 2010 | Frigidaire FRT21H8 Top Freezer...
Keep a refrigerator/freezer in garage. The
Good day,
Yes. Domestic appliances will not work properly below approx 55 degrees.
The freezer suffers most simply because the machine runs rarely at 55 degrees and degrades as the temp goes lower.
They are designed to balance properly when in an environment where people live. Ideally 70 to 90 degrees Fahrenheit.
The machine is not broken.
Moving it inside, is the only solution.
Thank for using Fixya
Jan 02, 2010 | Frigidaire Freezers
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Freezer not working in garage top mount freezer on refrigerator
Sears is technically correct. It wouldn't work with the old coolant either. The principle is simple. The refrigerator is the same temp as your garage - it is not running. It must be in a 60 degree room to work properly. The sensor to turn it on is in the fresh food compartment, and it never calls for cooling; therefore it appears you freezer only is out - but they both work together. Hope this helps!
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Cold garage interferes with top freezer keeping cold enough
Sorry it took awhile but there is not a cold area kit for this refrig available. it needs to be used in a controlled climate so that the controls will operate properly thanks for your patience. Peyton
Jan 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Whirlpool Freezer doesn't freeze?
insulated or not, garages are generally too cold for new energy efficient frigs to operate. ambient temp needs to be above 60 to work efficiently.
Mar 07, 2008 | Refrigerators
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
