Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
What is CC1, CC2, CC3, CC4, TEXT 1 -4? - ViewSonic N2750w 27 in. HD-Ready LCD Television
How do I turn off the closed captioning?
Press the closed captioning button a second time.
Mar 20, 2016 | LG 47LS4500 47 Inch 1080p LED LCD HDTV -...
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How to remove black square from the screen without the original remote?
Usually need the original remote--if you can with buttons (not likely on JVC) try to set it to CC4 which is almost never active and should remove the text box that you are seeing.
Note: if using a cable or sat box look there also as most have the text feature also.
Apr 26, 2012 | JVC Televison & Video
Closed caption is on the screen and i can't remove it.
On your TV Remote:
CAPTION Cycles through the Closed Caption:
?? Anlalog Closed Caption:CC1/CC2/
CC3/CC4/TT1/TT2/TT3/TT4/Off
?? Digital Closed Caption:Service1/
Service2/Service3/Service4/Service5/
Service6/Off
May 05, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do you remove the subtitles?
Subtitles are controlled by 'CC". Closed Captioning. Look for a CC button on the remote or captioning.
Captioning usually is in the menu as well under 'settings'.
Closed captioning has several settings. OFF turns all captioning off. CC1, CC2, CC3 & CC4 are captioning styles. Text is for text channels.
Mar 31, 2010 | Toshiba 57H84 57" Rear Projection...
Closed caption
CC (Closed Caption)
Press the down button to highlight the CC (Closed Caption) selection.
Press the > button. A separate menu will appear with the following CC
settings
CC
When watching regular analog (NTSC) TV, the CC feature is available in the
Setup menu.
Press the down button to highlight the CC selection.
Press the > button to select CC1, CC2, CC3 or CC4.
Once the adjustments are completed press the LAST button repeatedly to exit
the OSD completely.
Closed Caption for regular TV is usually CC1 or CC2.
Mar 02, 2010 | Vizio VO42L 42 in. LCD TV
Have a black-out square appear on some channels especially FOX
GO INTO THE MENU AND TURN THE TEXT OFF. THIS IS ASSOCIATED WITH THE CLOSED CAPTION. CC1, CC2, CC3, CC4, T1, T2, T3, T4, OFF
Jan 22, 2009 | Broksonic TV
Subtitle
Analog:
1. go to setup menu
2. press the DOWN menu button to highlight the analog cc section
3. press the right button to select off/cc1/cc2/cc3/cc4 (keep in mind closed caption for reg tv is usually cc1 or cc2)
digital:
1. Go to that handy setup menu again
2. Press the down button to highlight the digital cc selection
3. press the right button to select OFF or SERVICE 1 thru SERVICE 6 (any of these should work)
Dec 01, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
I wonder how to set up closed captioned with this phiplips remote control HildaBaugh@comcast.net
Sometimes its in the menu of the tv . Look thru the menu you should find it . If your remote has the button on it keep pressing it should give you different cc1 cc2 cc3 cc4 - text1 text2 text3 text4. text mode is not what you want it will block out the picture except for the edges .To turn off simply press the cc button until the off is displayed . Good luck
Feb 29, 2008 | Televison & Video
Closed caption
Go thru menu pages one at a time until you find CC / Text...
Selections might be CC1 , CC2 , CC3 , Text 1 , etc. You may
have to try each CC for your signal source......T.
More details = more help !
Nov 07, 2007 | Philips Magnavox 27MS343S 27" TV
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
754 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
