Question about Linksys Wireless-G WRT54G Router
Linksys wireless access
I am trying to set up a new laptop to have wireless internet, but the WEP kep i have is not working..i tried logging in to 192.168.1.1 but the password i have must have been changed- is there any other way to access the WEP key
There should be a recessed reset button on your router. Using a paper clip or something small press and hold the reset button. While holding the button, unplug the power adapter and continue holding the button for ten seconds plug the power adapter back in, and continue holding for another ten seconds just to be through. This should do a hard reset and your router will return to the default. For the default you have no username and your password is admin.
Posted on May 14, 2008
Hallo! my computer do not accept the router. I set up many times but nothing is working with Wlan. in otherside, the internet ist working via broadband - Linksys(INTERNET) - Linksys(port 1) - Computer. It...
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
May 09, 2011 | Linksys Wireless-G WRT54G Router
Just got a new linksys e3000 router. all other laptops working fine except one toshiba with vista. i have another toshiba with vista that is working fine also though. it will connect wirlessly if i disable...
You have to update the wireless adapter driver on the toshiba website. I'm guessing you have an Atheros adapter because those usually have this problem. The driver is not advanced enough to log onto a WPA or WPA2 encryption, WEP will work fine. The driver updates have a 50/50 chance of fixing the problem otherwise you are stuck with WEP.
Jan 11, 2011 | Linksys E3000 Wireless Router
What is a WEP key for a Linksys WRT400N wireless router?
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Linksys WRT400N Router
My Linksys router went off, and when I tried to reset it, it reverted to the general linksys name on the wireless networks but I still can*t connect to the internet wirelessly, only if I use a direct cable...
If you have power and you can connect via Ethernet cord no the router is ok.
You will need to set the wireless settings correctly in the router setup page.
instruction set here:
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
Oct 11, 2010 | Linksys Wireless-G WRT54G Router
No connection between the router and the internet. There is connection from the computer to Linksys.
1.Log into router
Jul 25, 2010 | Linksys Wireless-G Broadband Router
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
I can't access the internet after setting a security code in my router. What can I do?
1.Log into router
4.. Check the laptop do ipconfig /all to see current IP adresses.
Jun 28, 2010 | Linksys Wireless-G WRT54G Router
How do i do a password set up so no one with a laptop can use my internet
Log on to the router page
Access the wireless settings
Go to Wireless security mode
Select the wireless security mode as WEP/WPA
Enter the security Key
Use Characters(A-F) and digits(0-9) for WEP key
Feb 17, 2010 | Linksys Wireless-G WRT54G Router
Can not get the second laptop on the internet with the wireless
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Dec 26, 2008 | Linksys Wireless-G Broadband Router
Can't find wep key or router username or password
Since you want to access the router setup page and get the wireelss security for your laptop you can try this:
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
If the default password didn't work you need to reset the router by pressing the reset button for 15 seconds so it will be back to its default settings with default password which is admin.
But if you successfully log in to the router page just go to the Wireless tab and there you can find all the wireless settings of your router including the wireless security key...
Nov 17, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
