Question about Exercise & Fitness
Nordictrack vertex 670 how to assemble - Exercise & Fitness
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
NordicTrack C900 Pro Won't turn on
Double check:
Chances are that "$%#T Happens" is not your problem. And that if it worked prior to "dis-assembly, it should work after re-assembly". The common denominator is you took it apart & put it back together. So.. something was missed. A wire not connected, a switch not flipped, a wire in the wrong spot, the safety key not in the slot, etc, etc.
Good Luck
Mar 06, 2015 | NordicTrack Exercise & Fitness
Need instruction/assembly manual for this product
My wife finally found a number that will email you a PDF file that has the assembly instructions. Here it is. The name of the company is Sports Power 866-884-0535.
Oct 23, 2013 | Sportspower Vertex 2 Piece Table Tennis...
Vertex ce82 on my laptop says ce92win power on radio trying to program vertex 2200 mobile radio
Hi Shawn,
The problem is on the screen for you to see.....
You need to downgrade your CE OS to Win CE82, else you r Vertex software won't work, but downgrading is futile, so unless you can get hold of a friends Pocket book PC running Win CE OS 82, you may have problems.
This is a Win CE Operating System fault rather than Vertex software fault.
You say laptop, Win CE OS is for the smaller Pocket Book PCs as far as I'm aware.
If you're running that OS on a laptop PC, that can cause you lots more problems.
I hope this answer clears up the issue a little.
Regards,
Peter
Oct 21, 2012 | Vertex Vx-2200 Vhf 50w 134-174 Mhz 128ch...
Hi, I need the schematic diagram for marantz pdm679, Someone can help me? I am jorge, audiohertzio@gmail.com
Jorge,
The schematic will be part of the service manual, which gives a complete explanation of dis-assembly, circuit function, parts, & adjustment. You can purchase a service manual for the Marantz PMD 670 at http://www.servicemanuals.net/ServiceManual/MARANTZ/pmd+670/pos1/results.aspx
Anthony Beeler
Oct 10, 2012 | Marantz PMD670 Desktop Digital Voice...
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Aug 10, 2010 | Nordic Track Nordictrack Apex 6500 Reflex...
Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
On COD4 I keep on getting this problem: UBYTE4N vertex data.
you dont have a compatible graphics card or if you do you need to update the drivers
Aug 07, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Vertex data not supported... help
update your vga adapter from here: http://support.acer-euro.com/drivers/desktop/aspire_t690.html
Dec 25, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Determining the equation of the parabola
V (2,0) and Focus (2,2)
since the focus is 2 units above the vertex, the parabola opens upward
vertex (h,k)
a is the focal length (distance between the vertex and the focus)
a = 2
(2 units above the vertex)
(x-h)^2 = 4a (y-k)
(x-2)^2 = 4(2) (y-0)
x^2 - 4x + 4 = 8 (y)
x^2 - 4x + 4 = 8y
x^2 - 4x - 8y + 4 = 0
**Answer: "(x-2)^2 = 8 (y)" or in expanded form "x^2 - 4x - 8y +4"
Nov 18, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Exercise & Fitness Logo
183 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
