Internal hard drive disc 2 failiure - Computers & Internet
  • 17,130 Answers
No way but to replace the unit. Must get help to recover the data/files present in the hard disk by using a recovery program.
Check for bad sectors, and unless with the available good sections a partition can be done to make the hard disk work , you will need a replacement.
Posted on Sep 12, 2010
Trying to put internal hard drive to disc
save the harddrive on computer open files your want to burn you cant burn all on one disk
Mar 15, 2015 | Video Cameras
Lenovo Y510 says I need to Reboot so select proper Boot device. Can I downloan something from Lenovo site?
Yes you can obtain recover software from Lenovos' website for your model that should take care of your problems.
Jan 27, 2013 | Lenovo IdeaPad Y510 Notebook
Hard disc not recognised
internal drive not recognized might be kaput
try F8 at turn on for safe mode
May 29, 2012 | Toshiba (V000011180) 60 GB Hard Drive
Seagate's DiscWizard, Extended Capacity Manager didn't recognize a hard disc with MBR partition style larger than 2TB when trying to maximize the capacity of the 3TB Seagate ST32000641AS drive...
Seagate Extended Capacity Manager
Seagate Extended Capacity Manager lets your operating system support large size discs with MBR partition style, so then you are able to use the space beyond 2 TB: this free space will be recognized as a separate disc, and will be accessible by your operating systems and applications as if it was a regular physical hard disc.
Seagate Extended Capacity Manager wizard will display all hard discs larger than 2 TB (unallocated or with MBR partition style). You can see, which disc space is recognized and allocated by Windows - this space is called Native Capacity in the wizard.
The space beyond 2 TB is displayed as Extended Capacity Zone. You can enable Extended Capacity Discs, and once it is done, this space will be visible by the operating system and ready for disc management operations.
Click Allocate space to see the possible disc space allocation in the next step.
After clicking Apply changes now button, the Extended Capacity Discs will be emulated on your physical disc. In case your physical disc is larger than 4 TB and the host operating system does not support a GPT partition layout, there will be several Extended Capacity Discs.
Note these Extended Capacity Discs are not bootable, and most properties will be the same as a physical disc's.
After allocating the space, you may temporary switch off Extended Capacity Discs by clicking the corresponding option. This will make Extended Capacity Discs invisible for Windows Disc Management tools, though the disc space will remain allocated.
To disable Extended Capacity Discs, click Remove partitions from Extended Capacity Zone and then click Apply changes now button in the next step: these discs will be removed from your system, and as a result - the disc space beyond 2 TB will become inaccessible
Sep 15, 2011 | Seagate Technology Barracuda Xt...
Hi, can i install a 720 GB internal hard disk for my acer veriton? my present configuration are windows 7 pro,32 bit 160 GB HDD. thanks in advance.
I found a pdf manual here and it shows that this computer does not have SATA ports, but does have 2 IDE ports, so if it's an IDE hard drive you want to install then you should be able to. However, your 2nd IDE port is likely used by a cd/dvd rom drive, so unless you are replacing the hard drive rather than adding one, you would need to remove the disc drive. There are very affordable external usb disc drives available.
Aug 23, 2011 | Acer Veriton 7200D PC Desktop
My internal hard drive crashed, can i clear out this hard drive and reload the system and start up disks or should i just get a new hard drive. Also is there any way to retrieve files from the crashed...
Hi I am Steve, lets get you some help
As you are talking about a hard drive I assume you have turned off RAID.
It does depend why the hard drive has failed. If it is an actual failure of the drive then it needs replacing and the data is lost except from data recovery firms.
However, it may be that the hard disk controller has stopped working. This will prevent you getting to your hard disc.
Your motherboard should have 2 hard disc controllers. Try plugging the hard disc into the second controller, this will be on the motherboard next the the one it is already plugged into. This may solve the issue. If not then it is a hard disc failure and you will need to replace it and use a professional service to recover the data.
Jan 14, 2011 | Gateway (M520HD80G) Hard Drive
I have a SonyCyber shot DSC W120. super steady shot.A box comes up " no memory space on internal memory". I can not get it read my memory disc. I formated the internal memory. Any solutions
Sony recommends to use the preinstalled Hard Drive as the Recovery Discs works with the specific Hard Drive. However, you can add additional Hard Drive to the Computer.
Please check the link below for more information.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C127565
Your computer is shipped with 80GB Ultra ATA/100 Hard Drive. you can use Hard Drive of size 80 to 500 GB for best functionality.
May 07, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
Xbox 360 Multiple Failiures.
This is a help forum not to complain, please dont waist our time...
Sep 06, 2009 | Microsoft Xbox 360 Console
Hard drive
Sounds like your hard drive is toast but £145 for sony to replace it sounds expensive, you should just be able to replace it with any 2.5" internal sata drive
here is an example of one
http://www.play.com/PC/PCs/4-/9663375/Toshiba-MK5055GSX-500GB-2-5-Internal-SATA-Hard-Drive/Product.html?source=5066&engine=froogle_pc&keyword=Toshiba+MK5055GSX+500GB+2.5%22+Internal+SATA+Hard+Drive+(Sony+Playstation+PS3+Compatible)
That one is about £80 but im sure you can find cheaper, the best news is that replacing the drive doen't void your warranty which is good, here is a link to really good guide for replacing your ps3 hard drive
http://boardsus.playstation.com/playstation/board/message?board.id=ps3media&message.id=62981
good luck, let me know how you get on
tim
Jul 04, 2009 | Sony Playstation 3 (PS3) Console
Problem swapping hard drive
Smart errors are telling you the drive you are inserting will fail soon. It has recorded errors that indicate that drive is no longer usable. The drive still may work right now. But there is no telling when it will bite the dust. It could be 2 hours, it could be 2 months. I would trash the drive with smart errors.
Jun 25, 2008 | Maxtor Hard Drive
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
