Question about Kenmore Elite Oasis 27052 Top Load Washer
I am getting an error code F1 does anyone know what that is. The manual states to call for service? i am trying to avoid that as i have already had this machine repaired 3 times and am very dissappointed in this machine. Pls help. Thank you.
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 12, 2010
Display shows F1
The F1 code is an error code indicating that there is a loose of wire from it position or an over flow of liquid substance in the sensor /panel reading error i.e F1
what you need to do to fix up this problem is to unscrew the range with bass tools then clean up all form of liquid around the lens ,panel and also the wires and fix up the loose wire if any please do this with care in other to avoid more damage on it and while doing this DO NOT USE WATER or AND LIQUID substance in cleaning use only clean rag to do this service then allow it to dry up for some time then couple it back to it position with this the problem of f1 code is solve.
Thank you and thanks for using fixay.
Sep 10, 2010 | Dacor ER36D Stainless Steel Island Trim...
States F1 everytime going to wash
Call Whirlpool Customer Service at 800-253-1301
tell them you have a F1 code appearing repeatedly,and that you are aware of a "rework" issue regarding the control board, and that you want a service call to be set-up, This is a VERY common problem with this machine, along with the F-51 code which is a bad RPS. The control board will need to be replaced.
www.appliancehelponline.com
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error code
check the FixYa website for other solutions for your model, look for one with 29 postings........
Feb 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Technical details of permanent failure: Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the...
Google tried to deliver your message, but it was rejected by the recipient domain. We recommend contacting the other email provider for further information about the cause of this error. The error that the other server returned was: 554 554 delivery error: dd This message is looping: it already has my X-Yahoo-Forwarded line. (#5.4.6) - mta1023.mail.sp2.yahoo.com (state 18). --
Feb 15, 2010 | Yahoo Mail
My 2005 Suzuki Boulevard C-90 doesn't start and is showing error message F1 on the display.
According to the owners manual an F1 reading indicates a problem in the fuel injection system. The owners manual states that you should take it to the dealer to have it checked out.
The Clymers manual says that there is a certain "mode select switch" you need to recover the trouble code for what the problem is. That part # is 09930-82710. It hooks into a harness plug just behind the steering head covers.
Without knowing what that code is I can't tell you what is wrong with your bike.
Feb 09, 2010 | 2005 Suzuki Boulevard C90
I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
Dec 07, 2009 | Cars & Trucks
Temp stays at pre-bake 170 degrees oven does not ignite
We are Amana factory authorized service and parts supplies. We have all the parts that you need for you oven.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will give you all the information as well as get the correct part out to you asap.
We look forward to getting you up and cooking again.
Thanks, Ella
Nov 10, 2009 | Amana AOGD2750 Gas Double Oven
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Panasonic Workio DP-1820 error code E4-01
error code E4-01 means you have a fuser warm-up temperature problem. try a lbp fuser reset in service mode. i dont know what you password is so i cant tell you how to get there but good luck
Apr 16, 2008 | Panasonic Workio DP-1820E Copier
Kenmore Elite Oasis 27052 Top Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
