Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
Can't get the 4 motor to housing bolts off sp 1515-z-1 esc pump motor without twisting bolt into. have broke one as of now. Trying to replace pump seal. instructs say to remove 4 motor bolts to housing and push out seal from motor end. Looks like I will need 4 new bolts ans a tip to remove the remaining 3 bolts or just twist all 4 bolts off.
    President:
  • AO Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
As a rule, when we get those pumps in for repair and the bolts are breaking you notice the motor shaft is severely corroded as well. Often times that will make the unit unrepairable as the new seal won't hold up on a damaged motor shaft. If that is your case you will want to at least consider a new motor and seal for the pump.
If you can remove the bolts with or without breaking you can precede to attempt the repair. Bear in mind you will need to get the busted tips out of the pump housing in order to install the new bolts. That is not an easy task as you are working with a small brass bushing in a thin plastic leg. The removal easily damaged the pump housing. Try to work the bolts back and forth to free the tips. You will then need to get the broken tips out. If all goes well and the shaft is not too bad you should be ok. Anything goes wrong, replace the motor and seal and you'll still save some $$$ compared to a whole new pump.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 12, 2010
  • g_robinson20 Sep 13, 2010
    This is only the second season this motor has been used. The shaft is in perfect condition, no rust , just shiney and brand new looking. The four bolts just do not want to loosen up. Tied for a week gently trying to loosen and using all the tricks of tapping and lubricating. I think this is just a poor design. I f the motor was several years old I would understand.Anyhow my next move is to twist bolts off and try to get four new bolts to replace them with. Thank you. By the way I gave about $219.00 for the motor and did;nt get much use from it. Just bad luck
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I broke the bottom bolt on tha thermastat housing connected 2 the block
You have to take the thermostat housing back off and then you can use a "left hand twist" drill bit to drill the center of the bolt that you broke off. Most of the time the drill will "grab" the bolt and unscrew it for you. If not then drill deep enough to use an EZ out.
Aug 29, 2011 | 1995 Isuzu Rodeo
My husband was trying to remove 4 long bolts out of a swimming pool filter motor and 2 of the screws broke in half and the broken pcs are still in the small long holes. Any suggesions on getting them out?
If there is any of the old bolt still protruding from the housing, you may be able to force it out using a pipewrench, or other Stud-retracting tool. There is also a tool called an 'Easy-Out'. You drill a small hole in the bolt, and and this tool goes into the hole, and as you turn it, it 'grips' the old bolt, turning it out.
If these methods fail, then;
You will have to drill them out, and re-tap the threads in the holes. If the material that the bolts go into (the body of the pump) is made from a soft metal like aluminum, then you must be very careful when drilling, you must drill very straight. A Drill Press is recommended for this. After you have drilled out the old bolts, then get the proper Tap, and make new threads in the holes. Since you are making new threads, you will probably have to go to the NEXT bigger size of bolt, but make sure there is enough room, and material in the housing to accomodate the next larger size bolt.
good luck.
Jun 09, 2011 | Hayward 1hp Power Flo Matrix Above Ground...
I broke a part in the engine that i thought was the thermostat but it is not and no one can tell me what the name of the part is can you help
How did you think someone would be able to tell you what it is without any description or without being able to see it?
Jan 28, 2011 | 1988 Toyota Pickup
I need to replace the crank sensor on my 96 dodge with 5.9 cummins engine it i can not find it
The Camshaft Position Sensor (CMP) on the 5.9L diesel engine is located (1) below the fuel injection pump. It is bolted to the back of the timing gear housing (7).
1. Disconnect electrical connector at CMP sensor.
2. Remove sensor mounting bolt (6).
3. Carefully twist sensor from timing gear housing.
4. Check condition of sensor O-ring.
INSTALLATION
1. Clean out machined hole in back of timing gear housing (cover).
2. Apply a small amount of engine oil to sensor O-ring.
3. Install sensor into timing gear housing (cover) with a slight rocking action. Do not twist sensor into position as damage to O-ring may result. CAUTION: Before tightening sensor mounting bolt, be sure sensor is completely flush to back of timing gear housing (cover). If sensor is not flush, damage to sensor mounting tang may result.
4. Install mounting bolt and tighten. Refer to Torque Specifications.
5. Connect electrical connector to sensor.
Oct 17, 2009 | 1988 Dodge D-Series Pickups
How do you separate the motor from the housing?
Remove the bolts in the back of the plastic strainer housing, that will take the basket assembly off the pump.
The diffuser/ should be visible, this simply pops off with a little twist. The impeller should be now be visible
Remove the metal cap from the back of the pump.
Remove the rubber cap on the back of the motor under the metal case, (may not have one)
You will see a the back of the motor shaft and a slot that a flat head screw driver fits into.
Now is a tricky part that is somewhat dangerous.
You need to hold the impeller and turn that motor shaft with the screwdriver counter clockwise. It's best to hold the impeller with a rag for a better grip. You need to make sure you're using a beefy screwdriver that fits that slot well, or you might slip and jab yourself with the screwdriver.
It is tough to remove. Be careful.
Once the impeller is removed, you will see the seal plate, the bolts for this are on the back out the motor mount plate and can be removed with little effort.
You should now be down to a just a motor.
You may need to buy a replacement seal, as they tend to fall apart once tampered with.
Jun 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
1999 Park Avenue water pump removal
if thats got the 3800 or 3100 in it your taking out the wrong bolts!!!!!!!
your trying too remove the whole housing
you dont need too do that !!!
take off the 4- 10 mm bolts on the waterpump pully,then remove the bolts behind it i belive that there are 8 of them that takes the pump from the housing!!
May 10, 2009 | 1991 Buick Park Avenue
Overheating
Ouch! Was it from over-tightening or trying to remove the bolt?
Really, I need more information...
Regardless, you'll have to take the thermostat housing off and remove that broken portion of the bolt. The reason I asked if it was from overtightening, it should be a little easier since the threads aren't locked-up, to remove the bolt section. Hopefully there's enough bolt shank sticking up to lock some vice-grips to.
If the bolt broke trying to loosen it, you may have to drill into the broken bolt remnant and use an "Easy-out" to extract it.
I know... big pain. You can do it. Hey, stuff happens. Good luck!
Apr 25, 2009 | 1993 Saturn SC2
Move timing cover with the motor still in the car. go behind harmonic balincer
sounds like you have had a frustrating time.... sorry to add to it.... i believe the balancer has to come off to replace the timing cover.
Robert
Sep 27, 2008 | 1992 Cadillac DeVille
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
252 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
