Question about Associated Electrics XPS Micro Speed Control ESC
Hi, im using a team associated xps esc with the xp2 controller. the steering works,but when i use throttle, (both red and green leds are on) both leds turn off(red one slightly first) and nothing happens. i used to have a spektrum reciever in it, then it stopped working so i swapped all the original radio gear back in. still no throttle. thanks
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
Family fix maxi cosi Isofix and pearl car seat - I had to wash the car seat cover and since putting it back on and then clipped seat back into Isofix the led lights will not flash as green as they used to....
Hi Stacey
Red lights indicate an incorrect fitting. We would have to advise you that this base requires inspection to confirm it is working correctly. If it is under 2 years old and you are in the UK please contact your retailer with proof of purchase and they'll arrange for inspection & repair under warranty terms & conditions. If it is over 2 years old or you no longer have proof of purchase and you are in the UK please contact the customer care team. If you're not in the UK please go to www.maxi-cosi.com and select the country you're in, then use the Contact Us tab for your details to go through to the relevant customer care team.61bc5298-d763-4d9b-a1a2-7c3691a6859d.jpg
Nov 12, 2013 | Baby Gear
Vxl 3s turns on when i plug in battery, green light comes on, than red, than blinks through the racing and training modes, wont respond with button push
It sounds like it might just be a case of the button being stuck. The ESC shouldn't turn on just from you plugging in the battery, you're supposed to have to press the button once the battery's connected to power up the ESC.
Programming Your Traxxas Electronic Speed Control
Oct 17, 2012 | Traxxas Velineon VXL-3m Speed Control
Nissan pulsar 1987 n13 the ECM light came one and the car cut out and won't start again and I need to know where the ECM is
Hi, the computer is under the passenger's seat. Code extraction procedure is pasted below.
READING CODES Modes will not switch while the engine is running. The ECM automatically switches to MODE I when the ignition is switchedOFF.
1984-90 Vehicles With Dual LED System
The self-diagnostic system has 5 modes. To switch modes, switch the ignition ON and use a screwdriver to turn the mode select switch through the access port on the ECM. The inspection lights will begin to flash. When the desired mode has been entered, turn the screwdriver fully counterclockwise. The red LED and green LED perform different functions in different modes.
Mode I-
This is the normal vehicle operating mode. The green LED will indicate loop status. If the green LED is not blinking when the engine is running, the vehicle is in open loop, or the HO 2 S, O 2 S, or sensor circuit has a malfunction. If the green LED is blinking, the vehicle is in closed loop. If a malfunction takes place, the red LED and the MIL will glow, indicating a malfunction has occurred.
Mode II-
Both the red LED and green LED are used to monitor mixture ratio feedback control. The green LED will function as described in MODE I. If vehicle is in open loop, the red LED and green LED will remain on or off. In order for results to be valid, vehicle must be in closed loop. In closed loop, the red LED remains off if the system is running rich, comes on if the system is running lean, and blinks at the same time with the green LED if system is within 5% of the exact air/fuel ratio.
Mode III
-When this mode is accessed, the codes stored in the ECM's memory will be flashed by the green LED and red LED on the side of the ECM. The red LED will light first. This is the first digit of the trouble code; the green LED will flash next, showing the second digit of the code. For example: 2 flashes of the red LED followed by 1 flash of the green LED corresponds to Code 21.
Mode IV-
This mode is used for checking the throttle plate (TP) switch, starter, and vehicle speed switch status. When the TP switch or starter switch is activated, the red LED will briefly flash as the status changes. For VSS status, the green LED will remain off when vehicle speed is less than 12 mph (19 km/h) and come on when vehicle speed is greater than 12 mph (19 km/h).
Mode V-
This mode represents a real-time diagnostic test of the crank angle sensor, ignition signal and the mass airflow signal. The malfunction code will be displayed only when the malfunction occurs and will not be stored in memory. The output code will appear as a single or short string of pulses. Count the number of pulses for the malfunction code.
1 pulse-CMP sensor signal lost or noise in signal 2 pulses-MAF Sensor signal abnormal 3 pulses-Fuel pump circuit shorted or open 4 pulses-Ignition signal lost
Apr 19, 2011 | 1987 Nissan Pulsar
I just purchased a 1/16 e-revo with the brushed motor. I have had it less than a week and have run it a handful of times and it went really well most of the time. A couple of times it would just stop, I...
I have the same problem with my mini vxl slash sometimes and for me anyway I first unplug the battery, plug it back in, set the esc and then rotate the throttle adjustment on the transmitter reverse and then foward and for me that seems to work everytime. Dont know for sure if this is the same problem that you are having but I hope my answer helps...
Jan 17, 2011 | Traxxas 1/16 E-revo Brushed Truck Rtr 4wd...
Installing new flomaster xp2 pump. what color wies
Are you asking about the cord from themotor to the control? If so It should either be Green Black and white or all those plus a red. The green is the ground and it goes on the green screw. White goes to the common or line(1) post, and usually red is Hi and Blk low for the speeds. If it is a single speed only no red and black will go to the other line(2).
If this does not answer your question please post a comment with what wires and where you are dealing with.
Dec 18, 2009 | Water Heaters
Associated Electrics XPS Micro Speed Control ESC Logo
153 people viewed this question
Top Associated Electrics Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Associated Electrics Toy Expert? Answer questions, earn points and help others
