Question about Dell 3100cn Laser Printer
Get error message "004-321 Restart printer" Have tried everything.
    New Friend:
  • 36 Answers
This is a 'reseat drum' message. If you do that and make sure all is clean then restart it should be fine.
Posted on Sep 15, 2010
Resetting to factory settings trouble
You are caught in a loop. Have no recourse other than to use your restore disks and attempt a repair or new installation.
Sep 06, 2017 | Acer Aspire Z5600 PC Desktop
Did recovery, error message: encountered unexpected error
If you made backup recovery cd's do a fresh install of the operational system to factory setting.
Apr 17, 2012 | eMachines EL Computers & Internet
Hello my name is Amy and i recently had to do a complete system recover to my pc, Well when i went to reinstall my Kodak ESP.3 All-in-One Printer it loads the bojour and when it starts to install the Kodak...
Before you try re-installing it again, restart your computer. Sometimes installed programs require restart even if they don't force it on the user.
After restart try installing the software again, if it fails with the same error then your installer may be corrupt or not suitable for your OS. Go to the Kodak website and download the latest software and drivers for your printer. Here is the link. You will have to click on the right side on Downloads to select your OS and then search for ESP 5 will show up the results.
If you get the same error, check to see if you have the latest Service Pack installed (do a System Update for MAC). Update your computer and try again. By this time you have everything up to date and if it still won't work I'd say that there must be something corrupt into your OS.
Dec 05, 2010 | Kodak ESP 5 Printer
Unable to open printer(read error) this is the error message I have received. I have turned off the printer and the computer but the message is the same. I also deleted the printing job, turned everything...
try to remove printer from add printer wizard, unplug cable and insert, found new hardware must be appear, from that locate driver manually to initialize. restart pc and run test print wizard.
Mar 25, 2010 | Canon I960 InkJet Photo Printer
I have installed hp photosmart and get an error message '' restart print spooler error 1068'' I have tried everything but cannot restart my printer spooler.
go back to your services where you start the print spooler. open the dependency tab. there it will tell you what other services the print spooler needs to have running. check them and if any are disabled change them to auto and restart them. reboot and you should be OK.
Nov 05, 2009 | HP Photosmart 7450 InkJet Printer
Computer says it is busy when I try and print out a page, just installed new black ink cartridge and it won't try and print anything now.
1. Check to make sure the black ink cartridge is installed properly.
2. Check to be sure no printer alignment program is trying to run.
3. Right click the printer icon on the tool bar and see if any print jobs are still lingering. Cancel them or Restart them. Printer should pickup and start working from there.
Last resort:
4. Shut down the computer and unplug the printer for at least 1-2 min.
Restart everything paying close attention to any error messages.
If none, the printer should work again provided nothing serious has happened.
Hope this helps!
Oct 17, 2009 | Lexmark X2600 InkJet Printer
I have a all in one F388 that I bought in China. However after searching many post it appears I have a very common problem but no one seems to have a solution. Every time there is any type of paper jam...
Hi there. If the printer that you have is new try to call HP technical support for the replacement of the printer. Usually the warranty of the printer will last for a year. Here are the steps in resolving the problem. Clean the rollers of the printer with lint free cloth that is moist with water. Then try to print. If it would still reoccur try uninstalling and reinstalling the software but if it will not resolve the problem ask for a replacement.I would consider that a junk because that error message is a hardware problem.
Mar 06, 2009 | HP DeskJet F380 All-In-One Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
Dell 3100CN Error Message
I am a publisher here in Seattle printing full color books with this machine and I have just gotten the same message- Does anyone have a solution- I have Googled and checked everything... Now, this happened to me a few months ago and I pulled out the drum and sprayed it with air, replaced it and it worked fine for about two months- now I get the error again- does this help in the problem solving?
Jul 01, 2006 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
957 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
