Question about Corel Draw 8
Corel draw does not work with windows XP - Corel Draw 8
  • 5 more comments
  • antonio_tode Sep 12, 2010
    Thank you, but I hade no positive results. Coreldraw-8 file do not open anyway. Please better explain (step-bystep) your proposed solution or try to give me other solutions.
    Regards
    Antonio
    Thanks, but the steps you suggested are not working, I means no step can be done or completed.
    Maybe is ir important that I clarify that while opening a cdr file 1 windows opens "this is not a valid application od Win 32.
    Regards
    Antonio
  • antonio_tode Sep 13, 2010
    Thank you. I followed your suggestion and in Properties of Windows Explorer I found 3 options and I choose windows 2000 - which was the latest version available in that box. Well, now the cdr files can be opened, but just when Coreldraw is open, not directly the files from windows explorer.
    I think now the problem can be considered solved. However if you find out another trick to open file directly from windows explorer, this will be appreciated.
    Regards Antonio
    Further to my previous response, now I have discovered the trick for opening cdr files also directly from Windows Explores.
    Anyway thanks for your help.
    The problem is solved.
    Ciao
    Antonio
  • antonio_tode Sep 14, 2010
    100% satisfied.
    Thanks
    Yes, I had a 1000% solution.
    Thanks and regards
    Antonio
  • antonio_tode Sep 15, 2010
    100% satisfaction
  • 10,515 Answers
There is some compatibility issue with XP. Either you need to use a higher version or install some patches.
ftp://ftp.corel.com/pub/CorelDRAW/
http://www.corel.com/servlet/Satellite?c=Content_C1&cid=1153321224268&lc=en&pagename=CorelCom/Layout&pid=1151092456309
By the way, it is important with the X3 patches that you have your original install disks handy, also install them in order of how they are listed, starting out of order, does not work.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 12, 2010
  • 4 more comments
  • taran_2005
    taran_2005 Sep 12, 2010
    Thanks for your response!!
    You need to click on the links that i gave to you.Download and install the files. Once you would install the files, it could solve the problem.
    Let me know,if you need more clarification.
    Hope i helped you.
  • taran_2005
    taran_2005 Sep 13, 2010
    Till i check the files, you could try the below trick :-
    Right mouse click on the CorelDRW.exe file in Windows Explorer, choose
    Properties at the bottom of the dialogue box, Choose the Compatibility
    tab, click the box for "Run this program in compatibility mode for:" , choose the one you want to try from the drop down menu.Don't hold out
    too much hope for this working but it's worth a try if things don't
    work after you have cleaned the machine up thoroughly.
    Let me know the update so that we could proceed.
    Hope i helped you.
  • taran_2005
    taran_2005 Sep 14, 2010
    Great, that it worked.
    Let me know,if needed any further assistance.
    Hope i helped you.
    PS - Do accept the solution,if 100% satisfied from my response!!
  • taran_2005
    You need to accept my solution.
    Thanks and take care!!
  • taran_2005
    taran_2005 Sep 15, 2010
    You are welcome and take care!!
  • Norma Joyce Grundy Oct 05, 2012
    Ever since version 2, COREL has always had memory problems. I don't know how the versions since 6 are, but I find that using a Boost program such as JETBOOST, and a memory enhancer, particularly on Win XP, stops old COREL from getting Heap Errorsand locking up during Slideshows.
2 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Posted on Mar 28, 2009
Can not instal corel x5 on windows xp
dear for install coral draw x5 you have need install xp sp3 its must you can download it from Microsoft site free . for more info check on google
best of luck
Jul 06, 2011 | CorelDRAW® Graphics Suite X3 Upgrade...
I try to reinstal corel draw graphic 11 but it's always fail.. please guide me. i use windows 7
-Try to remove your older corel draw in control panel
-Delete folder corel draw in program files
-Restart computer
-Try to install corel draw again, Thx
May 31, 2011 | CorelDraw Graphics Suite 11 for Mac, PC
I have used CorelDraw 8 for years, and the clipart worked fine, even with Windows XP, but I installed CorelDraw X4 and installed it. But after Installing CorelDraw X4, I could no longer is CorelDraw 8...
I had a similar problem with Coreldraw 8. I used it successfully for years and loved it on varoius version of Windows, currently XP. I installed Coreldraw 12 and still had Corel 8 on the computer.
Now the problem: Corel 8 and Corel 12 could not open the Corel 8 clipart disk #2, only just down to the folder level. When I right clicked on the Corel 8 disk #2 clipart folder and checked the Path Properties it gave me a path other than the correct clipart disk location (in my case it should have read E:) BUT it was some weird location like
MNfisherman referenced above and read: C:\Documents and Settings\All Users\Documents\Corel.! What the?! I knew the path should have read E: to access the clipart since the clipart was on the disk and in my CD tray, so I uninstalled Corel 12 thinking that was the problem since 8 had worked fine, then checked the clipart CD again but still no luck.
I then uinstalled Corel 8, so now I had no Corel program on hard drive. I put the Corel 8 clipart disk #2 in the computer knowing it would not open the clips but just to see if I could get beyond the folder level to see if the clipart files were there and yes I could. (I could only read the names of the files at this point because no Corel on computer) So I only reinstalled Coreldraw 12 figuring the later version would open the older version clipart and Success! It worked. I think my problem had something to do with the Corel 8 MF indexer, but I'm not sure. I had a red semi circle (like the Corel Set Up Semi circle) on all of the clipart folders instead of the regular yellowish fold so thats why I think it had something to do with indexer or other type of setup conflict). Now all of my clipart folders appear normal being the regular yellowish color folder.
I suggest using a clean slate by unistalling all versions (Make sure you shut down the computer after each uninstall to get rid of all of the components of the program and then restart the computer) and then only reinstall the newest version. Hope this helps. Good Luck
Oct 15, 2010 | Corel Draw 8
G-Pen Genius 450 doesnt work in cs4,xp
I have two cricut machines that the start button will not turn the machine on. What can I do?
Apr 04, 2010 | Genius G-Pen F610 (31100050100)
My Corel Draw 8 locks up when I try to save my project. Any suggestions. I am using Windows XP
I have seen this under XP SP3. The following solved the problem for me.
Install Corel 8 from the CD. Reboot.
Get the 369 and 433 upgrades from the Corel FTP site. (Those upgrades are no longer available on the web site, but there is a pointer to the FTP site on the "Updates and Patches" page).
Apply the 369 patches. Doesnt matter what version the CD is -- the patches check to see if they need to be applied. Reboot.
Apply the 433 patches. Reboot.
Start the XP Compatibility tool. Make the settings for PhotoPaint and Draw "Windows 2000", "No XP Themes." Reboot
Mar 10, 2010 | Corel Draw 8
Know more about corel draw
You can use the following link to visit the website, in which you can learn many things about coral draw;
http://www.rnel.net/search/photoshop/coral_draw-tutorials-1
Feb 10, 2009 | Microsoft Windows XP Professional With...
CLARIS DRAW 1.0 print problem with Windows XP
Sounds like old software (1995) with a much newer operating system. I would upgrade to whatever is compatible with XP or take your OS back to what works with the software. I'd go with Corel Draw with XP. Vintage software has to be run with the same vintage OS to work properly. Hope this helps!
Jan 07, 2008 | Claris Draw (DRAWV1) for Mac
Corel Draw 8 Logo
458 people viewed this question
Top Corel Computers & Internet Experts
photoshop serial
Dan Shibata
Dan Shibata
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
