Question about Kenmore 62982 Electric Dryer
Dryer won't heat
It tumbles but will not heat. I have replaced the heating element twice in the last 5years.
  • Anonymous May 31, 2008
    my kenmore 80 series dryer model # 11070812990. heating coil? heats up gas kicks on, flame kicks on for 10 min. flame goes off. coil heats up no flame for rest of cycle. on the high "cotton" setting. when set at say 40 mins. what do i do?
    Guru:
  • 859 Answers
Hi Aaagh,
First, it is too bad Sears isn't what they used to be when it comes to services and warranties.
Second, if you've had to replace your element twice in five years and I guess you don't want to again, the issue is in an area that is considered rather dangerous to tinker with and complicates your options.
Third, then... do you consider your user skills high enough to mess around with high power energy power transformer circuits? Working around your source problem MAY KILL YOU.
This is where you are having failures. And, as a result and because of the need to drain off the stored energy in the power transformer I can't emphasize enough that it can kill you if you DO NOT know your way safely around these electrical components.
Why is this happening to you? Probably because you have had power brown outs while drying clothing and the transformer circuits has had to compensate and try and try to provide enough energy to keep your element hot that the brown outs have over taxed your dryer power supply and just given up or completely failed.
You may have also had power spikes going to the transformer that have at first created an abnormal burden on the transformer that it has now lost the integrity of its engineered physics and has had a complete failure of a critical component.
Realize, this is only a guess AND you will need a qualified service technician to replace this expensive component.
That said, and re-emphasizing that you must know what you are doing around these components or they will kill you, you may be able to find a replacement part from an appliance parts supplier who may or may not sell it too you based on the same issues of safety I just emphasized. And, your local laws may only allow a licensed electrical contractor to purchase this type of part.
In the end, I believe you need to address why your power in the home is doing this to your dryer and it is probably affecting your other high energy appliances in the home too. It comes down to this:
a.) you may not have enough energy in the circuit feeding your dryer.
b.) the circuit supplying your dryer has another high energy appliance on it such as an electrical water heater which should be on another circuit.
c.) you probably could use a "Whole House Power Surge Protector". The surge protectors are installed, by licensed electrical contractors only, depending on local laws. And, they run around $200. Since they cover all circuits in your home they are generally worth it if power in your neighborhood is weird.
If you have natural gas in your area going for a natural gas dryer will be a better investment in the long run.
Lastly, your homeowners insurance may cover you or have coverage for this high cost damage. You may also be able to change over to energy efficient appliances through your Energy Company as they may have a program for converting appliances to Energy Star qualified. They will usually do a survey for you for free however, but there may be a waiting line to get into their free swap over programs.
Please rate this reply to your problem. Even though this is really bad news I've given you and do not suggest you do this yourself, if it gives you a starting point to proceed in the right direction PLEASE rate this as fixed. I'll be most happy to help you further if you need it. Just click on my user name and then Ask Me and I'll get back to you as soon as possible.
Hoping this has fixed your problem,
Worldvet
Posted on May 14, 2008
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
Just replaced the heating element
Apr 11, 2009 | Dryers
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
Nov 01, 2008 | Dryers
Kenmore 62982 Electric Dryer Logo
141 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
