Question about Hilti TE 7-C 120V Rotary Hammer Drill
How to open hilti drill te 72? - Hilti TE 7-C 120V Rotary Hammer Drill
    Scholar:
  • Hilti Expert
  • 123 Answers
To seperate the motor housing from the gear housing you need to loosen up the two 5mm allen head bolts at the base of the handle. At the top of the handle you will see a hole. there is a 5mm allen head bolt that you will access through that hole. Back that screw all the way out. The lay the tool with the gear housing down and the motor up. Remove the 5mm bolts holding the two housings together. Tapping with a soft blow hammer you should be able to seperate the housings. Be carefull that you don't lose the lube out of the housing.
Here are instructions on removing the front end.
If yours is a metal housing here is how you disassenble the front end.First you need to put a flat bladed chisel in the chuck. Then lock the chisel in a vise. Next you put a pipe wrench on the chuck cap nut. That is the piece on the end of the chuck. Using a cheater bar turn the nut off counter clock wise. You then can remove your chisel, the cap nut, an oring and the locking sleeve with two rollers. This will expose the chuck that is held in place with 8 5mm allen screws. After that you have a large snap ring to remove before pulling out the rest of the front end assy
Posted on Sep 14, 2010
I have hilti te 72 it works but will not hammer
More than likely the con rod is broken. To check remove the shift lever on top by removing the center phillips head screw. then with internal snap ring pliers remove the snap ring.put your phillips screw back in with out the shift lever. Take a pair of pliers and grab the screw and pull the shift boss out. You then can see if the con rod is broken or not. The bad news is those parts are hard to come by.
Dec 15, 2010 | Hilti Drills
Amount of oil
Around 50cc's if it is still wet. 70cc if dry inside
Aug 02, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Turns but does not hammer
Hilti no longer carries parts for the TE72. You would have to find parts on Ebay or somewhere like that. There is a good chance that the con-rod is broken. Taking off the selecter lever on top. Removing the snap ring and then pulling out the shift boss will allow you to view the con-rod.
Jun 03, 2010 | Hilti TE 70 Hammer Drill Performance...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
I need brushes for a hilti te-72 where can i buy parts
go to Hilti.com and you can use their locator to try and find local suppliers or order them direct. You can also call them at 1-800-879-8000
Mar 14, 2010 | Hilti Drills
Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
HILTI TE 72 STOPPED HAMMERING BUT STILL WILL DRILL
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Mar 07, 2010 | Drills
Where can I find a switch for my Hilti TE 72 drill?
If you go to the German e-bay and search for hilti TE 72 , you will find answers to all your needs.
Rgds Egil
Oct 28, 2009 | Drills
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 7-C 120V Rotary Hammer Drill Logo
1,598 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
