Program of remote control
I would like to add to the remote of the tv the control of the cable box. It´s a General Instrument CFT 2200
  • 3,037 Answers
Try this website and download your manual,
http://www.remotecodelist.com/remotes/
tell me if you need any further help or if the link doesn't work, thanks
Posted on May 14, 2008
I have a bose universal cineomate solo 2 and I need the remote control code for my starview 7 digital cable recevier
About 66,600 results (0.76 seconds) Search Results
    STARVIEW HELP FILES ' AfterDawn Discussion Forums
    forums.afterdawn.com > ... > Home theater > Digital TV - UK & Europe
    Jul 6, 2007 - 11 posts - ‎3 authors
    Posting codes to the forums is no longer allowed. ... Connect your box and PC with a Null modem cable and switch on the cable ... 7. One of the listed ports should indicate which port your USB adapter is .... Using this method my Starview indicated it scanned 56/56 ... go to parental control in receiver menu Starview box
    Jun 15, 2014
    All New Starview HD Combo unit
    Nov 1, 2009
    STARVIEW UPDATING FIRMWARE - NO CODE ...
    May 14, 2008
    More results from forums.afterdawn.com
    Looking for a Universal Remote Control code (4-digit) to ...
    nordstromchicago.com/Looking_for_a_Universal_Remote_Control_cod...
    ... digital cable terminal? I need to reprogram my cable remote to operate my digital cable terminal. ... Code for Hugh button universal to control Dion free view box ... read more ..... I need the remote code for starview 7 remote control? Trying to ...
    Phantom Digital Cable TV Receiver. - TechKings
    www.techkings.org > ... > General Cable TV. > Phantom
Jan 28, 2016 | Bose Televison & Video
How do i program a radio shack 15-2200 5-in-one remote control for a tv code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 12, 2014 | Televison & Video
I need the remote that fit this tv
Hello
Buy one UF4-200C Four In one Cable TV remote control of US electronics. Your Proscan TV is listed it its codes. The code is
125
Setting up Your Remote
The UF4-200C is already programmed to control Motorola (formerly) General Instrument DCT1000,
DCT1200, and DCT2000 cable boxes. To control another device, look for the list of manufacturers'
three-digit codes for the device type in the Television Codes, VCR Codes sections, or Cable and Aux
Codes sections, then perform the following steps.
On the remote control, press and hold the appropriate mode key until the four mode
keys flash twice. The mode key will continue to flash.
Enter the three-digit code.
After you press the first digit, the mode key should light and stay on. After you press
the last digit, the mode key should flash three times and turn off.
If the mode key does not flash three times before turning off, the code is invalid for
this device type. Repeat the procedure with another device code.
Point the remote at the device and press POWER. If the device turns on or off, you
have finished programming.
If you have tried all the codes listed for the manufacturer and the device does not
respond, refer to the CodeScan™ section later in this manual.
More details are available with its manual you get with it.
OK.
Feb 04, 2011 | Proscan 32LB30QD 32 in. LCD TV
Through Amazon a Brookstone's "Jumbo Universal Remote" was delivered - there is no identification of who manufactures this remote. We need to have it control an AT&T-California cable box which was...
I happen to be a Jumbo Universal remote Expert here at Fixya, so I hope I can help. It is possible that this remote just won't run your Motorola cable box, but I wouldn't give up until I had tried the codes from the list in the manual, as well as run through the auto-setup feature of the remote for CBL and for SAT, where it just tries all the cable box codes one at a time.
I was able to find a working motorola codes for an Innovage Jumbo Remote, a three digit code remote you might as well try: 051.
You have probably tried the codes for Motorola (031) and GI (000, 032) from the manual using these steps:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device. (000, 031 & 032 for example)
3. Press and hold the corresponding button on the remote control
(CBL) for approximately three seconds. The POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press the ON /OFF button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code located on the Code List.
If those are still a bust, try the GI SAT codes 018 & 019.
Have you tried the following steps with both CBL and then SAT to search it's database?
2. Press and hold the corresponding button on the remote control
(SAT or CBL) until the POWER INDICATOR on the remote control illuminates. The remote control is in programming mode.
3. Press and release ON /OFF. The POWER INDICATOR on the remote control flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns off.
5. When the device turns off, press any key to store the code.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
I hope that helps.
Oct 26, 2009 | Televison & Video
Need set up codes for cft 2790 akai tv
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Dec 31, 2008 | Akai CFT2490 24" TV
Gain control of my Motorola cable box with a Sony RM-Y167 remote
Cable Converters (Set Top Boxes)
Director 0476
General Instrument 0476
Jerrold 0476
Motorola 0476, 1376
Pioneer 1877
Scientific Atlanta 1877
HOPE THIS WILL HELP YOU!!
Feb 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Remote control codes for general instruments cable box
i have a curtis mathes tv called an itronics and i need a remote controll code for it
Jan 15, 2008 | Nikon MC-EU1 LCD Remote Control
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
