Question about Scorpion Axial Racing Rtr Axial Ax10
I rolled my ax10 and now it will go forward and reverse and it will steer to the left but wont steer back to the right or straight. The suspention is fine, nothings bent or broken. Seems to be electrical and not mechanical but not sure what to do from here. HELP..lol
Ive done that many times chech the servo saver on your steering i strip them all the time
Posted on Aug 29, 2011
Jazzy goes fast in forward slow in reverse
It is supposed to. Forward you can see where you are going and normal steering applies. In reverse, you can't really see where you are going and it is only for backing up. Also reverse steering applies, so you turn left to go right, which is confusing for old folks, especially at speed. In Forward, the throttle should be responsive, slow to fast.
Feb 03, 2017 | Health & Beauty
Why do my steering wheel shake really fast right to left after installing a rack and pinion and power steering pump?
did you bleed the air out of the power steering lines -
Getting Air Out of the Power Steering Pump and Lines how to bleed air out of power steering lines Yahoo Video Search Results also if you didnt properly set tie rods or have alignment done your wheels wont be rolling straight and can cause wobble
Sep 13, 2016 | 1996 Ford Taurus
When steering is centered the left wheel is out to the left and the right is straight
Unless you have had an accident or Kerbed the wheel it is probably your tracking is out/ track rod end loose!
Sep 10, 2015 | Cars & Trucks
Key wont turn
try turning the steering wheel hard over left or right (both) while trying to turn the key with the normal amount of force. (never force the key)
most likely, it is just the steering wheel lock stopping the key from rolling forward.
Dec 30, 2012 | 2001 Land Rover Discovery Series II
When I make a left turn my steering wheel changes is neutral position
Something is loose on your steering linkage or suspension have a pro look at it, use a shop with an alignment rack available.
Aug 22, 2012 | 1994 Toyota Camry
Genius MaxFighter F-16U ... When i get into ANY game with Joystic support .. Jet fighters and etc ... I Pull the joystic and it wont pitch ...also it cant go right when i pull the stick to the right . ...
Hi, When you set your joystick up using the in game controlls menu try this. Try setting the controls from the bottom up I will try to explain. Lets say in the controls menu from the top it starts like this> 1)Pitch forward 2)Pitch backward 3)Roll right 4)Roll left. Start with pitch backward and pull the joystick back, It should auto input the pitch forward control. Next you would move on to roll left, It should auto input the roll right control. Get what im saying, You should only have to input one direction the other should auto input. Had the same problem with my LG extreme pro for BF2. Hope this helps good luck!
Jan 04, 2011 | Genius MaxFighter F-16U. USB PC Joystick...
Springs weak, Suspention problem. Shakes left and right, or up and down, while traveling down the highway, at certain speeds, or with rolls or bumps in the highway . Can anyone help with a diagnose of...
I WOULD LOOK AT THE SHOCKS FIRST 97 IS REALY OLD ENOUGH TO HAVE SPRING PROBLEMS LIKE THAT UNLSEE THE VENICLE HAS BEEN GROSSLY OVER LOADED OR TAKEN OFF ROAD AND BEEN DRIVEN HARD A LOT
Oct 17, 2010 | 1997 Nissan Pathfinder
I have a 2004 Chrysler Pacifica. When ever I make a left or right turn, either going forward or reverse, there is a cranking sound. It kinda sounds like a knocking sound.
dear friend-it might sound silly but when ever you make a ful lock turn to the left or right,it is like the body wants to break away from the suspention,it is normal wear and not easy to get rid off.
Sep 23, 2009 | 2004 Chrysler Pacifica
Scorpion Axial Racing Rtr Axial Ax10 Logo
144 people viewed this question
Top Scorpion Toys Experts
ray gallant
Are you a Scorpion Toy Expert? Answer questions, earn points and help others
