SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
SOURCE: Magic Chef Mini-Fridge not Working, Model # MCBR360S
Unplug and look for the thermostat control. Try jumping the thermostat wires together. If it runs then replace the thermostat. Also feel the compressor to see if running, they run very silently. Thanks, Sea Breeze
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
SOURCE: my mini fridge will not work. compressor is hot.
Believe you need to change the start relay and overload, Sea Breeze
SOURCE: Magic Chef mini fridge stopped working. I hear a
You have either a bad capacitor or a bad compressor. If I were there I would put a part on called a 3 in 1. It's made by Supco. It replaces your relay Overload and start capacitor. If the compressor is good, it will fix your problem. Click on this site and you will see the part I'm talking about. It's very simple to put on. http://www.appliancepartsonline.net/index.php?target=categories&category_id=50 The part number is RCO410
Please rate this solution and good luck!
Testimonial: "Very helpful. I'll try it."
