Question about AKG K 240 Studio Professional Headphones
I have AKG 141 studio headphones and the right hand side earpiece wont make any sound, i believe it is faulty wiring because if you move it around you can make it work.
Take away the glued brandmark with a sharp tool (knife , little screwdriver) and you will find a screw. loosen it and open it. there you will see some cables witch probably have one loose. fix it by solding it.
Posted on Dec 05, 2010
  • Dion Jul 23, 2012
    THANK YOU THANK YOU THANK YOU! I was stuffed trying to find how the earpiece was secured. Stupid metal sticker. May great karma rain down on you in high fidelity sound!!!!
No sound is coming out of the right side of my AKG K 518 LE
If you click my user name you will find a tip about headphones that might be able to help you.
Apr 01, 2011 | AKG K 240 Studio Professional Headphones
How can i open my AKG k141 studio headphone to repair it ?
I had a problem with my AKG K141 Studio headset. The right side stopped working. Hard to believe but one of the leads to the ear speaker was disconneted from the solder lug. To disassemble, pry the gold AKG emblem using a jeweler's screw driver. You can pry it without damage by locating a small notch on the black plastic rim at the 6 o'clock position. Then unscrew ththe tiny phillips screw and remove black disc. You will see two leads (red and white) feeding through a hole. Disassemble removing a larger screw. This will give you accesss to the solder lugs.
Nov 30, 2010 | AKG K 240 Studio Professional Headphones
The left and right ear bud work some times. and if i turn the base were you plug it into the device it coukd work how can i fix it so they can both work at the same time.
Probably can't. What typically happens is that the base of the wire gets stressed from wrapping the cord around you media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more carefull with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Skull Candy LINK Earbuds Consumer...
I got a skullcandy TI 1 year ago, and since two days the sound comes out normally, or without the left side, depending on the position of the wire connecting the MP3 to the skullcandy. It's very sensitive,...
What typically happens is that the base of the wire gets stressed from wrapping the cord around your media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more careful with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Audio Players & Recorders
Sound went out on the right side of earphones
See my tip on dodgy cable/plugs on headphones.
Jul 10, 2010 | AKG K 240DF Professional Headphones
Left ear bud lost all sound- no cord damage-only 5 months old...is it worth getting fixed by professional or is there something I can do to fix it ? H
The cords are sealed into the earphone. You can take a multimeter and test the continutity of the either earpieces, once you are convinced that the left side is faulty, first of all use a small thin needle as the probe, use your multimeter in the continuity range, holding one end of the meter probe to the jack , inset the pin like an ijection into the wires to obtain the connection, it there is no connection out of the headphone jack, I think you can replace with a new one to be soldered. If not proceed to the earpiece to confirm, then open the sealed unit and be lucky if the earpiece is not damaged but only the wires. Good Day
Jul 07, 2010 | AKG K 321 cloud white Headphones
Right speaker is not operating on a set of AKG headphones.
Go in by the part that fits to your ear. You will need to remove the ear pad. Also the foam, you might have to force the foam off, you can glue it back when done. With them gone you should see access screws.
Feb 16, 2010 | AKG K 240 Studio Professional Headphones
The 2 wires red and white came apart from the right ear phone
This might help:http://www.metacafe.com/watch/1045725/how_to_solder_how_to_repair_headphones/
Oct 12, 2009 | AKG K 240 Studio Professional Headphones
AKG K240S headphones not working well.
A buzz in one ear and no sound in the other 'sounds' like an open connection inside the headphones. The K240-series uses three wires from the pin to the headphones. Try this link to get wiring schematics and disassembly details: http://www.akg.com/site/powerslave,id,7,nodeid,7,_language,EN,cat,11.html
DHE 2008
Jan 07, 2008 | AKG K 240 Studio Professional Headphones
AKG K 240 Studio Professional Headphones Logo
842 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
