Question about GE Dryers
Dyer is making squeeking noises? Can I lub it to fix that?
  • 101 Answers
No needs slides and rear berring
Posted on Sep 12, 2010
Ge profile is making loud squikei noise how to fix it
is it a scraping squeak or a squealing noise?
Jun 09, 2012 | GE Dryers
My dryer squeeks while it's running. How do I get into the dryer to lub the belt.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a canon pc850 the roller is squeeking.
Wich roller?
If the sound is geting from drum unit, replace drum unit.
If sound is getting from bushings or axis apply small amount of wd40 or similar.
Jun 29, 2010 | Canon Office Equipment & Supplies
Drum noise
Did you ever figure this out??? Ours just started doing this
Nov 29, 2009 | LG Dryers
Squeeks from front end, 1999 explorer sport
you did not indicated when the squeek occurs. If you turn the steering wheel and there is a dry squeek look at the tie rod ends. If you bounce the truck and the squeek is heard look at the stabilizer bar bushings {most common cause } If this is the cause, lubing them is a temporary fix they should be replaced.
Feb 19, 2009 | 1999 Ford Explorer
98 Ford Ranger Squeeks when accelerating
do you hear the squeeking in the truck only if so then its the little o ring plastic in the peddle makeing the noise.
Feb 04, 2009 | 2003 Ford Ranger Regular Cab
Squeeking noise when drying
you have a whirlpool made kenmore dryer , there are 3 moving parts that can be making this noise , the belt tensioner and 2 wheels that the drum rolls on .
to get to these parts you go into the front of the unit. start by removing the 2 screws on the top where the lint screen inserts. then get a flat screwdriver to pry the top of the dryer away from the door panel it should have clips holding it down on both sides of the front.
after that you can see the drum with the top open like a hood of a car , look inside there are 2 screws holding each corner of the front of the dryer , they are 5/16 hex heads , remove these screws and the entire front door panel will come loose , pull the panel upward to release the lower clips holding it.
Now that this panel is removed look under the drum to see how the belt is held so you can put it back correctly , after removing the belt pull the dr om out and you will see the wheels , you can use motor oil to oil the center of the wheels and the belt tensioner. to get the drum back in set it on the wheels and roll it untill it falls into place and reassemble the rest if you have any other questions let me know and tell me how it works out.
Phil
Jan 07, 2009 | Dryers
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Steering awkward and squeaky wheels.
Hi, We have a pram ora duoletto which had the same problem we brought wd40 from robert dyers and it worked a treat it fixes any squeeks. It costs about £3.75 but will last an age. We sprayed our wheels a month ago and there have been no more squeeks since.
Hope this helps.
Jul 22, 2008 | Bertini Bidwell 905 Horizon Standard...
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
