Question about HP Compaq ProLiant DL380 G4 Server
I can´t use a serial ata disk in a proliant 350
I want to install a serial ata disk in a hp server proliant gl350, its necesary to install serial ata drivers.?
thanks
  • chakrabortya Oct 11, 2008
    i have a ibm server computer model no. system X3200.it has a 80 gb scsi hdd, when i want to install any os on that hdd windows can't find any hdd in the system. but when i remove bootable os disk, system was boot from it.
    Problem Solver:
  • 17 Answers
I know ATA disks are cheaper , but they don't last as long or are less reliable.
I do not recommend mixing SCSI and ATA .
Use one or the other , not both.
Do not try , unless your server is non critical.
If it is non critical , why bother with server , a PC will do as well.
Thanks
David
Posted on May 27, 2008
    Problem Solver:
  • 5 Answers
Hi JChamaleon,
Well u can install the SATA hdds in the server however it depends on the kind of controller these hard drives are connected. It also depends which generation server it is .
If the SATA Harddrives are connected to Embedded SAS/SATA controller You will have to install the controller drivers . This could be done using a USB floppy driver Press F6 during OS installation .
Note : Depending upon the kind of controller, drivers can be downloaded from the HP website . if it is a adaptec controller check during the POST what kind of controller it is ( It might says SAS1068 during the POST) and check for the same driver in adaptec website .
Following is the List of ML350 Series servers and their base model controllers :
Note : these server has optional controllers as well which can be found in the quick specs. Just google quicspecs <ML350 G5> you will get the info .
HP ProLiant ML350 G4
# Integrated Dual Channel U320 SCSI Adapter
# Smart Array 641 Controller
HP ProLiant ML350 G4p
* Integrated Dual Channel Ultra320 SCSI Adapter
* HP integrated 2 Port SATA controller
* Smart Array 641 Controller (Standard in Array Models only)
HP ProLiant ML350 G3
Model dependent:
* Integrated Dual Channel Wide Ultra3 SCSI Ultra160/320 Controller
* Smart Array 641 PCI-X controller (3.06GHz models)
* Smart Array 532 PCI array controller installed on Array models (older models)
Compaq ProLiant ML350
Integrated Dual Channel Wide Ultra3 SCSI Adapter
Compaq ProLiant ML350 G2
* Integrated Dual Channel, Wide Ultra3 SCSI based on Adaptec 7899W/7902 Ultra160/320 Controller.
* 2 x 68-pin internal connectors located on the Server Feature Board.Smart Array 532 array controller installed on Array models
HP ProLiant ML350 G5
Entry Models
* Smart Array E200i Controller with 64MB of Cache
Base Models
* Smart Array E200i Controller with 128MB and BBWC
hope this is helpful
cheers :)
Posted on Jun 05, 2008
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
Open Proliant ML350 G4 tower without the key
use minus screw driver. I opened it with the same :)
Jan 07, 2012 | HP ProLiant ML350 G4p Server
How to install scsi driver for hp prolaint ml 350 server and then install server 2003,because my os 2003 is currpted.
windows server 2003 enterprise edition with SP1 or SP2 , can detect
SCSI driver automatically.
Apr 22, 2011 | HP Compaq ProLiant ML350 G3 Server
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
Hard disk not found message coming while installing windows server 2003 on Hp Proliant ML150 G5
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
Feb 15, 2011 | HP ProLiant ML150 G5 Server
ProLiant DL160 G6 Server, Part Number 593352-B21, Serial Number USE029N5Z2. The system fails to power on. The power supply has the LED light green. The start button does not turn amber. Do not...
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Aug 04, 2010 | HP ProLiant DL160 G6 Server - 1 x Xeon...
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
Feb 01, 2010 | HP Compaq ProLiant ML350 G3 Server
I lost bios admin password in hp server dl380 g i want clean password without Remove the server cover. please help me.
Mfraid the only way to erase a BIOS password is to open up the case and remove the battery from the motherboard.
Aug 08, 2009 | HP ProLiant DL380 G5 Storage Server 9TB...
HP Compaq ProLiant DL380 G4 Server Logo
803 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
