Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Where is the water filter on the Whirlpool ED2CHQXKB05. Please.
4 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: my whirlpool model # ed2chqxkb05 is not making
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Posted on Dec 13, 2009
  • 109 Answers
SOURCE: Whirlpool ED2CHQXKB05 question:where is the water
its not under the grill its the big round hole on the grill
Posted on Jul 28, 2010
SOURCE: Cannot find the filter on
From what I can see with your model number you do not have a water filter contained within the cabinet. You can install an inline water filer between the source and the refrigerator. Also, you will likely have hard water stains in the ice maker mold itself, FYI.
Posted on Oct 01, 2010
Replaced water filter on a Maytag refrigerator it uses whirlpool filter. when filter is replaced and you try to use the water dispenser you get a loud grinding noise from the filter, how do you fix this?
I need to know which model you have, because i would explain the issue you have better. I thin it would be a MSD model and it could mean a board collision in the touch panel to the dispenser.
Please let me know your model so I can help you further.
Good Luck
Sep 01, 2013 | Whirlpool Refrigerator Water Filter
I have a model ED2CHQXKB05, series SR4452983 from November 2004. Freezer on the left side. The freezer drips into a vented area in the back: I can see the drips when I open the door, and each drop makes a...
What you are describing is the normal sounds it makes when it goes into defrost. The frost melts, and the resulting water will fall onto the heater which then makes your hissing noise. You dont mention that there is a problem, such as not cold or water leaking on your floor, so it sounds like all is working as it should. But you also mention you taped IT ( what is it?) to the wall in a circle.
Oct 12, 2010 | Whirlpool Freezers
Cannot find the filter on the whirlpool ED2CHQXKB05. The ice maker is producing ice with a white film on it. I was told to change the filter only I cannot locate a filter.
Oct 01, 2010 | Refrigerators
My whirlpool model # ed2chqxkb05 is not making ice, we can still use the water in the door. its not making ice. Help
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator gushing water through ice maker filter
Filters themselves don't usually leak. Check full insertion of filter, cracked filter housing or cracked supply line.
Aug 14, 2009 | Whirlpool Refrigerators
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
189 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
