Question about International Playthings Calico Critters Townhome
I need a new light, do you know where I can get one?
I have purchased a new remote for my sanyo tv. the lights on the remote buttons will not light up.
J. if you know the lights on remote are to light up and they do not, it is defective, return for replacement or refund. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sanyo DP19649 Owner Manual Remote Control Operation
How to Program Universal Remote Welcome to Remote Central Universal Remote Control Reviews More
Apr 12, 2016 | Sanyo DP19647 DP19648 DP19649 DP26640...
How do i know if my computer is bad on my gmc truck
computer does not control headlamps.could be loose ground or daytime running light module.turn lights on with switch does it still flicker? or are you talking about batt light check plug for tight fit on alt.
Feb 15, 2015 | 2000 GMC New Sierra 1500
Abs light came on
First --lets make it clear ,that since the beginning of time ,there
are no idiot lights,they are there for a reason
Next-- you repair ALL things you know need replacing
Then-- check over ALL work you paid for--who knows how that
was done
Only then--do you work on the new issues
If you had no problems,then --yes--you always repair
code related issues first
Dec 09, 2012 | 1994 Mercury Villager
I dont know why my external hard drive isnt showing up on my computer i think its lock, i dont know how it happen it was working fine a couple of days ago.
If the power light is on then I would get a new USB cable for it. If the power light is not on then you might need a new power cord.
Mar 04, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
I need to know how to remove a thermal light
take a 7/16 wrench, and where it is attached at the gas valve, unscrew it and then follow it to pilot light and it should just pull out of the hole that holds it to the pilot light
Sep 05, 2009 | Dryers
How do I know if my printer needs a new print head
You will know if your printer needs a new print head when you encounter:
1. Light printings
2. Misaligned prints
3. When you refill the ink cartridge, the printing has poor results.
Aug 20, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
New drum wont work
It sounds to me that your maint counter needs to be reset. 24-7 will reset drum. Let me know if you need help getting into the simulation.
Feb 12, 2009 | Sharp AL-1530CS All-In-One Laser Printer
I don't have the owners book for my 2003 VW Beetle and a indication light came on that I don't recognize. I need help knowing what it is please.
Which indicator light is it? New beetles have an array of warning lights all around the speedo cluster. I have a shop manual for the new beetle. Let me know which indicator light it is and we will try to figure it out. Thanks.
Dec 22, 2008 | Volkswagen Beetle Cars & Trucks
International Playthings Calico Critters Townhome Logo
79 people viewed this question
Top International Playthings Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you an International Playthings Toy Expert? Answer questions, earn points and help others
