Question about Encore ENHWI-G2 Router
Can't connect my laptop in my router and every time im not connected. i have to turn it off and turn it on again. sometimes for several times i need to turn it off and on again. and i tried to reset it because i am thinking maybe it helps. but i lost my password. i just want your assistance how to put security password? thank you
    Scholar:
  • 104 Answers
To get the password you have to contact the server.You should write your password in a book,not on the PC.
Posted on Sep 12, 2010
Why I cant log on my account instead the phone kept on searching the hole time
It is maybe because of your internet connection. Try rebooting your router if you are using a WiFi. Turn it on again and connect your phone. Also, you can check your internet connection's speed at speedtest. Just search it in google :)
Sep 05, 2016 | Cell Phones
Tip
How to fix limited or no connectivity message with your wireless network...
How to fix limited or no connectivity message with your wireless network connection
When you move between wireless networks that use the same IP range and/or hardware it is some times necessary to manually renew your IP address for the new network because the computer still thinks it is connected to the old network.
Note sometimes all you need to do is reboot your computer and the computer will reacquire a valid IP address but from time to time a reboot will not fix the problem and you will need to go through the steps below.
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Now at the command line type "ipconfig /release" and press Enter
4. After the first command runs you will be at a command line again now type "ipconfig /flushdns" and press Enter
5. Now you will need to enter one more command, type "ipconfig /renew" and press Enter
At this point if you are wireless connection is not already connected it should be reconnecting to your router.
If you still get the limited or no connectivity message make sure that the router is getting an internet connection. You may need to restart your modem then your router to make sure that the router is connecting properly to your modem.
Also note in my example pictures you can see several connection listed this is because my notebook is connected to several networks. If you have a high number of connections you may need to reinstall the drivers for your network card. Doing this will dump and cached setting that may be causing your connection problems.
on Nov 20, 2010 | Computers & Internet
I have Belkin F5D7234-4-H V5 Router and I have one computer connected by cable and laptop connected by wireless. Computer on cable have constantly connection to the internet, but time to time laptop losing...
Go to http://setuprouter.com/router/belkin/f5d7234-4v5/login.htm and then follow the instructions following: Login to the Belkin F5D7234-4v5 Router and work your way down through the instructions.
Jun 12, 2017 | Belkin F5D7234-4 Router
Wireless Problems Zyxel P660HW-D3
When you defined the name for Wireless connection with you new router, did you give it a new name? If this is a case then you can delete the old name in your available wireless network list in your lap top so it won't go back to the default one which is the old one, then you are all set.
Sep 07, 2009 | Zyxel P660HW-D1 Router
Lynksys Connectivity Problem
occassionally, the wireless router needs to be turned off and on. The are some issues with regards to the stabitlity of these entry level wireless routers. What I do is put a timer at the outlet to reset it every morning. cheers!
Oct 16, 2008 | Linksys Wireless-G WRT54G Router
The internet light turns off very often
If your DSL light goes off and comes back after sometime...then there is a possibility of issue with your Broadband service provider....there may be some outtage in your area.
  1. In order to confirm check the phone status when there is an issue?
  2. switch off and switch on the CPE ( some CPE has this issue)
Jan 15, 2008 | Zyxel Prestige 660R Router (91004397002)
Can't connect to laptop
Open your network connections and enable the wireless adapter. that should get your wireless working unless your antenna is not turned on, You should go into your control panel and check if the wireless in there is on, Let me know if that works if not there a several different things we can try.
Dec 23, 2007 | 2wire HomePortal 100W (1000-400026-000)...
DI-Link model DI-704
I have the same problem... my connection after an hour will slow down but after i turn off and on the router again, my connection will back to normal again... Can u please help... thanks.
Dec 09, 2007 | D-Link DI-704P Router
Losing internet connection when I try to connect laptop to wireless router
Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
Nov 29, 2007 | Belkin (F5D7230-4) Router (587009)
Encore ENHWI-G2 Router Logo
56 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
