Question about Carrier 38CKC036 Air Conditioner
The motor area is iced up on the machine, and the fan is not blowing cold air?
  • Brian Niten Sep 12, 2010
    Are you talking about the indoor unit or the outdoor unit?
    President:
  • 3,074 Answers
You will need to clean the coils, with a water hose. make sure you have the power off. This will de-ice the unit. as it is either diry coils or low freon
Posted on Sep 12, 2010
Freezer works but refirgerator is not cold
when you open the freezer door do you hear the fan blowing?if not you have a bad evap fan motor,if the fan is blowing put your hand on the back inside wall of the freezer,if you feel like snow on the back inside wall you have a defrost problem and have to find what part is bad with a meter,bad defrost thermostat,heater or board or timer,send model number next time,ice builds up on the coil and air can't blow into fridge from freezer,could have a bad damper,also if the freezer is on top you could have a blocked drain in the freezer,the air vents freeze up and the fan can't blow air from freezer into fridge because the air ducts are frooze up,all it does is the freezer gets cold,the evaporator fan blows cold air from freezer into fridge section,so either the fan motor is bad,the fan blade is damaged or something is blocking the air like a bad damper or air ducts are frozen up,send the model number and let me know what you find,do you hear the fan,any ice on back freezer wall or anything else you see and i'll try to help you out.
Jun 02, 2012 | Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
Freezer works fine. Refrigerator does not keep food cold.
all the machine does is blow cold air from the freezer to the fridge side with a fan and then the air returns through air ducts,first off open the freezer door,you should hear the fan blowing,if not you could have a bad evap fan motor,next from the bottom up in the freezer,remove the second up from the bottom shelf or bin and put your hand on the back wall,is there like snow or ice on the wall?if so you have a defrost problem.let me know what you find and i can help you better
Oct 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice is forming in my Freezer and the roof is forming drops
Unplug it and let it defrost. wile it is defrosting pull the botum front cover off and vacum out all of the acumulated lint off the tub on the bottum. after about 2 -3 hours plug it back in and listen for the fan running on the inside if you feel air coming out of the vents then you should be OK. If no fan replace it.
Sep 11, 2009 | Kelvinator 24 in. MDB421RF Built-in...
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Freezer not keeping ice cream cold
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
Nov 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Carrier 38CKC036 Air Conditioner Logo
43 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
