Question about Craftsman 16" Variable Speed Scroll Saw
The tension knob on my Craftsman 18" scroll saw keeps coming loose as I am cutting. Where can I get a replacement tension knob? Or how do I fix this problem? Thank you, Kara
rowdy45176
  • 2176 Answers
SOURCE: looking for scroll saw manuel
Go to Searspartsdirect.com and type in your model number. I checked and also found that a lot of parts for this saw are discontinued so good luck.
Posted on Dec 28, 2008
  • 864 Answers
SOURCE: Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
Posted on May 21, 2009
Vanguardian
  • 106 Answers
SOURCE: Manual for single speed scroll saw
Unfortunately it looks like you'll have to order it from Sears. And I don't know what the difference is between the 2 listed.
They are at the very bottom of this page.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=137286050&productCategoryId=0744440&brandId=0247&modelName=SCROLL-SAW&diagramPageId=00001&documentId=P9020197&pop=flush
Posted on Sep 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: need manual for 20'' scroll saw model 113.236400 Craftsman
go to Managemyhome.com and type in your model number the manual is 26 pages long. If I have answered your request would you please rate my response accordingly. Thank you.
Posted on Sep 20, 2009
SOURCE: I have a craftsman radial arm saw 113.23100 which
My craftsman 10-inch radial saw (model#113.199200) just stopped working. I had it in the driveway cutting some wood without any problems. It sat for a half hour and I went to use it again and it was running half speed then before I could even turn it off it just died. There was no popping sound or smoke, nothing! It will not start. Need help, please?
Posted on Sep 25, 2010
Sears 18 42cc chain saw blade keeps coming lose
I have found that the number one reason for a loose chain is from stretching, and that comes from heat or clearing small brush.
Heat being that it is not oiling properly and wears quicker, and the small brush answer (cutting lots of 1/2 in Buckthorn) tends to jerk the chain and manually stretches rather than a steady cut in a log which tends to be smoother.
With that said, yours might be something else. If I can ask a few question... When the saw was purchased, did you install the bar and chain? Second your level of experience - and is this your first saw. What I need to rule out is that the bar could be on wrong.
This saw was more than likely built by Poulan and it should have 2 nuts holding the bar. Does the bar loosen up? If the answer is no you might have a bar that is miss matched to the chain. What that means is that the chains "drivers", the tooth that is down in the bar could be a .050 and the bar could be a .063, hence the chain wobbles more that it should and might be more prone to jumping off.
Solution: Replace bar and chain and make sure they are a matched, lastly, always cut with a sharp chain.
Good luck,
kj
Aug 27, 2014 | Craftsman sears 18" Chain Saw Chain (...
Changing blade scroll saw
Loosen the knob at the rear of the top arm - turn it counterclockwise several turns. The blade should now be loose. Push the "blade end" of the top arm down slightly with one hand while you unhook the top of the blade. Lower the blade a little to unhook it from the bottom arm.
Replace the blade. Hook it onto the lower arm first - you can look underneath to see what you're doing. The blade's teeth should point DOWNWARD - it's easy to accidentally install it the wrong way, so check that now. Again push down slightly on the end of the upper arm, then hook the top of the blade into the upper arm's blade holder. It should how stay in place, but loosely.
Now return to that tensioning knob at the top rear. Tighten it slowly until the blade is BARELY tight, not loose. Tighten the knob 1/2-turn to one full turn tighter to tension the blade.
Jul 24, 2014 | Craftsman 16" Variable Speed Scroll Saw
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Sep 11, 2011 | Craftsman sears 18" Chain Saw Chain (...
My Craftsman 16" variable speed scroll saw worked fine the last time I used it. I tried to use it yesterday and now suddenly it seems to have the bottom arm of the saw working in opposition to the upper...
Try retightening the tension knob...not sure exactly hows its hooked on,but sounds like you may have backed it out too far.If simply turning the knob to tighten does'nt work,try either pulling up on knob a little while trying to tighten..or opposite-push down on it while trying to tighten...the idea with both is to get the threads on the tightening knob to catch the nut inside...my guess is it came off.
Aug 23, 2010 | Craftsman 16" Variable Speed Scroll Saw
I have a 18" Craftsman gas chain saw. It will not keep running, after two or three cuts it just stops and cannot be started again until it sits for 15 to 20 minutes. I have cleaned the air filter and...
Try removing the fuel cap for a moment, then try restart. If ok, check the fuel vent for plugging. Check the fuel filter for plugging. Inspect the fuel lines for decay or other damage. Check for spark when it stops--it may be the ignition module failing when hot. Check for sawdust and dirt plugging the ventilation system--blow it out with compressed air. Does the engine 4-stroke at speed when not cutting, but does 2-stroke when cutting? Make sure the chain is being oiled while running. Hope this helps!
Jul 13, 2010 | Craftsman 18" Chain Saw Replacement Bar...
HOW DO YOU CHANGE THE BLADE AND TIGHTEN IT UP THE BAND BLADE CAME OFF & I DONT KNOW HOW TO GET IT BACK ON
Unplug it. Open the cover(s). Find the tensioning knob - this is usually right on top, and it is raises the top wheel (or ins some cases an idler wheel) - thereby tightening the blade. Lower the top wheel by turning the tensioning knob a few turn counter-clockwise. This will give you enough slack to re-install the blade. Wear leather gloves and reinstall the blade. Tighten the tensioning knob a bit. Turn the wheel by hand a little to see that the blade tracks OK. Tighten it a bit more. The correct amount of tension pretty much has to be determined by trial and error. If the blade comes off, or bends too much while you try to cut, or cuts poorly, then it's too loose. If you over-tighten it you can break the blade or prematurely wear out your machine. Close the cover and plug it back in. You can adjust the tension with the cover closed, and you can even tighten it while the saw is running. But I wouldn't loosen it while the saw is running.
Jan 20, 2010 | Ryobi 9 in. Benchtop Band Saw
How to change the blade on a craftsman scroll saw? The manual was been misplaced when we moved
You might be able to find the manual on the Sears site (this can be a frustrating search - but start with the model number). But even without the manual, this is pretty easy on most scroll saws. There is usually a plastic knob (about the size of a ketchup bottle lid) on top of the machine at the back. You loosen this knob a couple of turns (to the left) and the blade will become very loose. The blade is probably the "pin-end" type - it will have a little cylinder about a 1/4 inch long on each end of the blade. You can buy new blades at any home improvement or hardware store. Besides qualtiy, the main differences will be the length of the blade and the size of the teeth (expressed as TPI or Teeth Per Inch). You need more TPI for cutting harder and thinnner materials, less TPI for softer and thicker material. Put the new blade in like the old one was (teeth pointing down) and tighten the plastic knob. It's hard to be sure how tight is should be, since it doesn't suddenly tighten up. About a 1/4 turn past where is starts to get noticeably tighter is a reasonable place to start. If the blade pops off during use, it wasn't tight enough.
Jan 14, 2010 | Craftsman 16" Variable Speed Scroll Saw
Saw has no power.
Does the motor continue to run, but the arm stops? It sounds like the set screw on the motor shaft is loose. See the exploded view at this link. It's called out as # 97 http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=5682&typeId=3475&documentId=333
Jan 13, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
How do I adjust a craftsman bandsaw to keep it from pinching when cutting circles. I have inheirted the bandsaw with no manual
Hi Alvin,
Lower the vertical guide down until it is just above the cutting surface.
However, a standard band saw blade is primarily for straight cuts. They are too wide to make sharp turns.
If you are attempting intricate work requiring extreme angled cuts, a scroll saw is better suited for your needs.
An alternative to check on would be if any thinner scroll emulator type blades are available for your model. They don't as well on heavy jobs, but you'll get the maneuvering you need on the thinner stuff.
Best regards
Mike
Nov 06, 2009 | Craftsman Saws
I have a Craftsman 10 inch band saw. The blade keeps coming off. I can't find my manual. How do I adjust the alignment on it?
the blade tension shaft in the rear top of the saw should also have a tracking adjustment knob that tilts the top wheel. Open the top guard and spin the top wheel by hand and adjust the tracking knob until the blade atays on. Better unplug the saw until you get this done, then you can power the saw back up and fine tune the tracking while running until it is perfect. hope this helps you.
Oct 17, 2009 | Saws
Craftsman 16" Variable Speed Scroll Saw Logo
Top Craftsman Measuring Tools & Sensors Experts
Vuk B
S Sigs
S Sigs
Are you a Craftsman Measuring Tool and Sensor Expert? Answer questions, earn points and help others
