Question about LG WM-2277HW Front Load Washer
Code ce dont turn on - LG WM-2277HW Front Load Washer
    President:
  • 1,932 Answers
The CE error code is indicative of an over current in the motor. Unplug the power cord, wait for 10 seconds, plug the washer back in, and restart the cycle. If same problem happens again, close the water tap, unplug the unit, and refer to service
Thank You
Posted on Sep 12, 2010
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
Hello. i have a 7"
from the problem description i guess the password which u r mentioning is for the BIOS.... u will have to contact the manufacturer to resolve this issue... they might have set a default password...
Mar 18, 2011 | Computers & Internet
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How can i fix the CE code on my washer? the CE code appears when i turn on the washer then it turns off.
The "ce" code indicates that a communication error occurred between the central control unit and the motor control unit. This can be caused by poor or loose electrical connections, especially at the motor connector. Unplug the machine before attempting any repair. The electrical connections can be unplugged and reseated to clean off corrosion. Also look for any damaged or burnt insulation on the wiring. If these steps fail to resolve the problem, you may want to consult an appliance repair technician for assistance. Sorry for your trouble and best wishes.
Sep 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
NTL CODES FOR DUBLIN DEC 24TH
Ireland CHORUS 5E 01
00: CE 19 2E 87 80 61 74 90
01: 62 FA D9 F3 CE 05 FA 79.
NTL 5401
00: B0 B8 4F 04 E6 5F 87 80
01: A3 EB EC 07 D6 49 D2 EB
THE 04 AND 07 TRY BOTH LETTER AND NUMBERS COS I DONT KNOW WHICH
Dec 24, 2008 | StarTech.com StarView SV211K 2-port KVM...
THE BOX NOT REDIEVING CHANNELS
dont know if this will help press menu then 1570 on remote check emu see if its on if not turn to on
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Casio ce-3700 e01
Hi. You have turned the key before you finished what you were doing in another mode. A flag clear will jump you back to reg mode. Try this:
Turn power off at wall.
Turn key to program mode.
Hold RECEIPT FEED button down.
Turn power on at wall and let go of RECEIPT FEED after 5 seconds.
You should see 'FFFFFFF' on display
Press SUBTOTAL
Turn key back to reg mode and try it.
Mark
Sep 11, 2008 | Casio Parts Cash Register PC Desktop
LG WM-2277HW Front Load Washer Logo
393 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
