Question about ECHO, Inc. PB-251C Handheld Blower
ON MY ECHO PB 230LN HAS NO POWER.SCREEN HAS BEEN TAKEN OUT OF EXAUST ,NEW CARB KIT,OLUG AND FILTTERS. STARTS FINE,IDLES BUT WONT PICK UP SPEED
I have the same leaf blower and what I did was took apart the muffler and inside is a small square screen. Your going to want to clean the screen and all other parts and make sure there is no build up. After doing so reassemble everything and it should work like the day you got it!
Posted on Apr 04, 2012
I have a echo pb-239ln blower .ivw checked the exhaust does not have carbon in it
still runs bad like it has no power with the muffler off .to u think it could be the carburetor needs to be rebuilt ?
Posted on Oct 23, 2011
  • 183 Answers
I think you are on the right track with removing the screen from the exhaust, but I feel your exhaust blockage is further back...possibly in the muffler or ,most likely, in the exhaust port itself. To check, remove the muffler and visually inspect the muffler port. If it is clogged, rotate the piston to the top of the cylinder and using a dull small screwdriver, chip away at the carbon until you have it clear. don't chip too hard, you don't want to damage the piston. Use some compressed air to blow away the debris. Lower the piston and blow away any stray debris that might have ended up in the cylinder. You can test run with the muffler removed, but only for a few seconds, and it will be very loud.
If the muffler port is clear and the test run without the muffler doesn't cause a significant difference in the engine speed, then the next course is in the carburetor. Most of Echo's current products use carbs that are not adjustable, therefore the carb must be rebuilt or replaced.
Posted on Sep 12, 2010
  • hallbrick May 08, 2011
    Per Echo service man: "Bad coil" Static discharge causes the advance timing circuit in the coil to short out. Fix is a new coil and add a ground wire to throtle area of the leaf blower.
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Starts dies
Fuel lines could be collapsing from being soft, mush from ethanol in gas, possibly you have wrong carb kit, or something put together wrong, fuel lines reversed, double check everything then make sure you exhaust screen is not plugged, cause this will do same thing.
May 24, 2013 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Echo shred n vac starts,idles, runs to about half power then bogs
Check the grommet that sits on top of tank where lines from go carb. Grommet may be rotten and crack. Try that. Have you ever replace the carb repair kit? The diaphram may be torn, defoam or have holes in them. Carb kit cost arount $10, but don't mess with the welch plug or screen in carb.
Feb 16, 2010 | ECHO, Inc. Shred n Vac
Echo PB-413H bogs down
Echo tools have a screen in the muffler to arrest sparks. Take off the muffler and remove this screen
Jun 03, 2009 | Echo Inc. 44 CC, Carb Certified Backpack...
Echo PB 2100 Leaf Blower will not speed up
Remove the muffler and clean the exhaust port, spark arrestor screen and muffler intake.
Apr 09, 2009 | Garden
Echco PB-230LN blower
Try adding some "Seafoam" brand additive to the fuel mixture, that did the trick for mine. Must have been something in the carb and the Seafoam cleaned it out, runs just like the day it came out of the box
Nov 01, 2008 | ECHO, Inc. PB-251C Handheld Blower
ECHO, Inc. PB-251C Handheld Blower Logo
661 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
