Question about Alpine MRD-M1005 1000 Watt Mono Amplifier Car Audio Amplifier
I have everything hooked up and i keep blowing the fuses in the amp?
  • 32 Answers
Did you use connectors on the amp or did you just strip the wire back then screwed the wire down? is the amp brand new?
Posted on Sep 12, 2010
Why does my spa 500 amp blow a fuse every time I hook up my 15" lanzar sub to it
Because it's drawing more power than the fuse can handle get a fuse with a higher rating. A 100 app fuse worked great for main power with my setup 760w amp a 15"sub 2 10"subs and a 12" sub. Also my amp had 2 30amp fuses on it one for each channel but I ran everything out of one channel.
Aug 02, 2016 | Lanzar Car Audio & Video
Hammond organ c2 hook to a 147 leslie speaker it keep blow the 1.5 slo blo fuse how do I fix this
Like all the past answers, make sure everything is clean and lubricated expecially on the Lesley if it's a motorized rotating speaker, the slow blow fuse is telling you there is a problem ?
Feb 22, 2015 | Music
My 03 cavalier stereo fuse keeps blowing
The remote circuit in your amp is probably shorted
Mar 07, 2012 | 2003 Chevrolet Cavalier
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
Avr 3802 can i hook up 2 sets of front speakers
well depending on the wattage of the speakers your trying to hook up to the amp if they exeed the maximum wattage then theres a chance u *could* blow a fuse nothing more then that, a fuse protects more expsinsive devices in ur amp, an if ur system keeps blowing fuses after doing that add up the watts 2 all ur speakers,
and remove the less needed
Hope you find this usfull
Feb 10, 2009 | Denon AVR-3801 Receiver
Wondering why im blowing fuses
The most common reason for an amp (in good working order) to blow fuses is a speaker load that's impedance is too low. You may need to rewire your speakers.
Let me know if you have any other questions.
Aug 21, 2008 | Legend LA1490 - American Legacy Series 2 -...
Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Jun 12, 2008 | Kenwood KAC-728S Car Audio Amplifier
Blowing fuses
Here are some answers:
1. Make sure your amp does not have a higher amp rating then the fuse, For example, an 18 amp amplifier will blow an 15 amp fuse, so connect it to a 20 amp fuse
2. you have a connection issue, where something is shorting out
3. you are pushing the amp or car to it's limit with how loud you put it, and thus blowing it, fixed by getting a more powerful amp and a better fuse.
4. or there is something very wrong and cannot help you and you would have to bring it into a shop.
Nov 18, 2007 | Car Audio & Video
Lanzar amp
If it keeps blowing fuses then #1 its internally damaged or "blown" .. Or #2 i would make sure you have the battery power hooked up to the + terminal and the ground wire running from the car body to the - terminal.. so if its hooked up correctly and keeps blowing fuses then it requires repair.. I wish i had better news but thats all it can be...
Aug 20, 2007 | Scosche Industries Scosche High...
Alpine MRD-M1005 1000 Watt Mono Amplifier Car Audio Amplifier Logo
69 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
