Question about Windchaser Wind Chaser Wall/Ceiling Fan With Remote Control
The rotating Ann Yih motor has stop working, where can I found a replacement in Canada? the motor model is AM-03 AC120V 60HZ, 3.7W, 3RPM CW/CCW, made by ANN YIH Precision Ind. co. ltd.
2 Suggested Answers
SOURCE: ERROR MESSAGE
The e-5 error message is caused by overheating. I had the same error messager a few months ago.
The problem was the air vent on the left side of the unit was clogged with fuzz from the carpet and dust which had accumulated over a two year period.
To fix the problem use a vacuum hose with a brush and try to get the bristles underneath the plastic grill and vacuum the metal radiator type unit underneath the plastic.
When the air vent is cleaned the unit will resume normal operation.
I had to (finally) unplug the unit and take it outside and clean the vent with a waterhose to get all of the gunk out. I also purchased a sheet of charcoal filter (a few dollars) and velcro and put my own makeshift filter on the outside of the housing over the air vent on the left side.
Posted on Feb 17, 2008
Where can I buy: #AM-03 E181521 AC120V 60HZ 3.7 Z.P. 3RPM CW/CCW
e-bay or you local repair shop for what ever it is
Dec 29, 2016 | Garden
Have a small safe with a three number combination. I am not sure how the numbers should be rotated.
Depending on the unit,, Make , Model etc.
It is usually CCW, CW, CCW sometimes 4 rotations to clear
go to first number, then 3 rotations CW to the next number, then 2 rotations CCW to the last number, rotate CW till the tumbler stops,
Then pull the handle to open, if in doubt,
Call a local locksmith who sells or services the unit and ask the
procedure for that model ,
They may be able to set you straight
Aug 22, 2014 | Home Security
Ann yih am03
HI TRY EBAY FOR SPARE PARTS
Apr 08, 2014 | Garden
Maytag bravo washer model number MTW6700tQ0 wont finish spinning please help!!
Hello c bellone,
If you rotate the clutch pulley by hand CW the tumblers should rotate in the wash basket.If you rotate the clutch pulley CCW the tumblers will rotate until the clutch spring comes under tension then the wash basket will begin to turn CCW and the tumblers will stop rotating because the transmission rotates with the wash basket. Do you have this action?
The clutch has been an issue for many are you taking dc or UC errors to the display?This clutch incorporates a Drawn Cup Roller clutch bearing (one way clutch bearing) designed to rotate freely CW and lock up CCW to rotate the spinner shaft in spin cycle rotating the wash basket/transmission CCW.You are halfway thru the clutch removal process, I would drop the clutch out and inspect the roller clutches, clean them up with WD-40 and some light bearing grease.If they are rusted up beyond clean up and or the clutch spring is broken as in this post you will have to replace the clutch.You will know what you are up against once the clutch is out and opened up for inspection.
Here is the process I use for clutch removal;
Access and remove the Clutch for maintenance
Disconnect 120VAC power cord.
Nov 27, 2012 | Maytag Bravos MTW6700TQ 4.6 Cu. Ft. Top...
What does line and tape mean dayton motor
L 1 is power in .L 2 is also power in.line means this is were the power needs to be hooked to . cw / stands for clock wise rotation . ccw stands for counter clock wise rotation.
Sep 28, 2009 | Air Tools & Compressors
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Diagnostic complete
Your washer apparently did not complete diagnostics. The display indicates that it stopped at the segment of the test where it was attempting to fill by using the hot water solenoid. The diagnostic test segments check the following:
C:00 - Door Lock
C:01 - Flow Meter, Cold Water Solenoid
C:02 - Dispenser Motor, Dispenser Contacts
C:03 - Hot Water Inlet Valve
C:04 - Motor rotates CW at wash speed
C:05 - Heater & NTC (Heater Sensor)
C:06 - Drain Pump
C:07 - Motor rotates CCW at 35 to 90 rpm within 15 seconds
C:08 - Motor rotates CCW at max. speed.
If there is an error associated with any portion of the diagnostics, the washer will shut down, an audible alarm will be heard, and an error (F) code will be displayed. Sometimes the washer will experience momentray glitches during testing, however. I would recommend unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). The is the main "brain" of the washer. Upon reset, attempt diagnostics again and let me know the results. I hope this helps you.
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Defective rotating grill motor
I have found the manufacturer of the motor in China and have ordered a replacement part.
Thanks,
Canadiano1
Jul 28, 2008 | Kitchen Appliances - Others
Windchaser Wind Chaser Wall/Ceiling Fan With Remote Control Logo
707 people viewed this question
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
