Question about JVC HD-61Z456 Television
My jvc model #hd-61z456 is working at too dark of a picture. I have replaced the light bulb twice and have reset the picture setting to factory setting and I don't know what else to do can you help me. Thanks
  • JVC Master
  • 8,457 Answers
Both times bulbs was replaced it lasted 1 1/2 or 2 years right?Use tv on like 4 or 5 hours a day?That the avervage life span of a projection bulb.Try to buy an original JVC pojection bulb last little longer.
Posted on Sep 12, 2010
How do i update the software on my jvc hd-61z456
Did you bump the lens? Is it blurry on all inputs?
Usually firmware is updated via a usb port
Oct 24, 2015 | JVC HD-61Z456 Television
Bought replacement bulb still won't work
is there a lamp reset in the manual? If the lamp won't power up, you will need a repair.
Aug 10, 2010 | JVC HD-61Z456 Television
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
JVC TV: Model # HD61Z456 61 inch - what is the modet number of the bulb that I need to replace. I have no picture on my screen.
The bulb part number is: TS-CL110UAA. Take out the bulb and look inside from the front side. Visually inspect any physical damage inside. If it looks clean, lamp might be good
Jan 22, 2010 | JVC HD-61Z456 Television
JVC HD-61Z456 Television to dark
Most likely a bad Polarizer within the light engine of which you cannot buy. The entire light engine would have to be re-built or replaced and they usually start around $600.00....
Jul 09, 2009 | JVC HD-61Z456 Television
Picture is still dark after new bulb
when you fitted the new lamp did you reset the lamp burn time??
if not the tv still thinks it has the old lamp fitted!!! clever these tv's
Jul 08, 2009 | JVC HD-61Z456 Television
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
Jvc hd -61z456
These guys are correct, you need a new dlp lamp. The lamp # for your particular television model is the TS CL110UAA.
Apr 21, 2008 | JVC HD-61Z786 61" Rear Projection HDTV
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC HD-61Z456 Television Logo
318 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
