My lap top tablet gateway cx 2620 is not working Does it have solution to repair it or I need to change all the display?
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Gateway CX 2620 unit won't turn on. Replace motherboard?
If the power LED is on then -
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 01, 2012 | Gateway Convertible CX2620 Notebook
NO WIFI DRIVER FOR MY LAPTOP MODEL GATEWAY CX2620
Please click on the link below to download the wifi driver for your computer
http://support.gateway.com/product/default.aspx?tab=1&modelId=3037
direct wifi link to download drivers
http://global-download.gateway.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Intel_11.1.0.86_Vistax64Vistax86_A.zip?acerid=634164273388886564&Step1=NOTEBOOK&Step2=CX SERIES&Step3=CX2620&OS=ALL&LC=en&BC=GATEWAY&SC=PA_6G
Feb 03, 2011 | Gateway Tablets & eReaders
How to get web cam to work on gateway lap top , no install disc
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 23, 2011 | Chicony TwinkleCam DC2110 Webcam
My newly purchased gate way NV53 model number MS2285 lap top computer gets blank before i create a start up disk ,so i will be pleased if you can help me to repair computer. ...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Gateway NV5378u Notebook
How do I install a keyboard in a Gateway M280E Tablet? (Directions with pictures a plus, but not absolutely needed.)
Power off and remove battery. Remove 2 screws on back cover marked with a K. Open display, gently pry off long thin silver panel between display and keyboard. With fingers at top of keyboard, pull up and flip top over toward ypu, then lay flat and upside down. Disconnect flat cable and remove the keyboard. Reverse steps to replace.
Apr 21, 2010 | Gateway M280E
Wen i conented the projector it not porject to my gateway lap top
Connect the projector and hit your function (FN) key and tap the F8 key. This should toggle the display to the projector.
If that doesn't work, look at your FN keys (top row) and look for a blue label for CRT/LCD and use FN+ that key.
Oct 12, 2009 | Gateway M305CRV Notebook
CX 2620 is slow...I have installed MS Office 2007 and the performance is significantly lower on the Laptop,,,should I add Memory?
Hi there.
Its always a good idea to max out the ram (memory) if you are using power applications like MS Office 2007, the maximum memory your laptop will take is 2GB (2x1BG) and i recommend kingston ram as its one of the best out there.
Good luck and thanks for using FixYa!!
May 13, 2009 | Gateway Convertible CX2620 Notebook
Tablet CX 2620 Display problems
You should angle the screen towards the light to see if you have a faint image on it. If so, the problem is more than likely a failed inverter, or CCFL lamp on the LCD itself. Either in which would have to be replaced. The CCFL lamp unfoutunatly part of the LCD it self and cannot be replaced seperate the screen. The inverter can be replaced easy as it it right under the screen. Symtoms of a failing CCFL could be the white comes out as red on the screen for the 1st 10 sec or so of startup. This will put alot of stress on the inverter causing the inverter to overheat and shut off. I have one to where the CCFL failed and am trying to find a replacement.
Good luck
May 18, 2008 | Gateway M1200-3004265 Tablet PC
My cd drive wont play any kind of cd
Just clean EYE on dwd IF IT WONT WORK the EYE is damanged.
But check if it showing in MY COMPUTER AND CONSOLE MENAGMENT
Nov 15, 2007 | Gateway CX200X Tablet PC
Computers & Internet Logo
David Payne
David Payne
