Question about Whirlpool Refrigerators
Whirlpool model GC5SHGXLB01 stopped making ice - any suggestions how to troubleshoot?
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 958 Answers
SOURCE: Stop making ice
check if there is ice in the ice maker, see if there is water coming in to the ice maker. maybe a water problem or a solenoid problem...if there is no ice in the ice maker...try to pour manually a cup of water on the ice maker and empty the ice bin so that you can observe if the ice maker is working if there would be ice in the bin after an hour. if there is ice, then a water problem is most likely to look at. i hope the freezer is working perfectly..
Posted on Feb 12, 2008
  • 37 Answers
SOURCE: Whirlpool Ice Magic Plus not make ice at all.
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out(beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Posted on Jan 03, 2009
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I have a Whirlpool Refrigerator Model 25SSA made
OK there could be several things to cause that. The dual water control valve is defective. Ice blocking the fill tube leading to the ice maker. Thermostat inside the ice maker. When the ice maker stopped what position was it in? Let me know and I will help you. Sea Breeze
Posted on Jun 21, 2009
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
It just stopped making ice yesterday. A question.
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Whirlpool Model ED25DQXXN side by side with ice maker running.
either lift the arm up and this should stop it or u can unhook the plug for the icemaker thats about ur only 2 ptions
Feb 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5VHGXML10. ice maker not working. Water not filling
If you look in the freezer there is a wire rod that goes from the ice tray to the bucket that the ice dumps into. As the level of the ice gets higher it pushes up on this wire rod to shut off the ice making operation. When the level of the ice drops the wire rod is suppose to drop and the ice making operation is suppose to resume. However a lot of times this wire rod sticks in the up position when the ice level drops. You just need to pull down on the wire rod. Try that, I think you will find that this is your problem. Please let me know if that worked for you. Thank you.
Nov 07, 2009 | Whirlpool ED5VHGXM Side by Side...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker working, water stopped dispensing
This could indicate the water valve on back that sends water to ice maker is not working. The coil can be checked with an ohm meter. I also can help you diagnose the problem. Send the model number of your refrigerator so I can help you better, Thanks, Sea breeze seabreezehvac@yahoo.com
Below you can visit my site and enter model and part numbers in search feature, we offer free help and assistance.
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
