Question about Acer AL1706AB LCD Monitor
Acer al1706 will not power up and makes clicking noise
  • Anonymous May 16, 2009
    no power, led off, source ok
Hard drive is knackered
Posted on Feb 19, 2009
The screen is blinking too fast to do anything I am on another computer now how can I fix it?
inputs are wrong. use the proper cable. Set up your video to extend displays. Change resolution.
Mar 31, 2014 | Chief Manufacturing Chief Flat Panel Dual...
ACER AL1706 powering up, green power light flashes once a second, faint 'flicker' on screen, eventually starts up with the Acer logo, and runs normally.
You may have dying power supply due to bad DC filter caps.
Please see failed ACER and other monitors to see if you will want to DIY repair.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Aug 28, 2010 | Acer AL1706b 17"LCD Monitor
I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Jun 10, 2010 | Acer AL1706AB LCD Monitor
I have an acer al1706 lcd monitor. it won't turn on. the power light is blinking every 5 seconds.
This is generally indicatve of bad capacitors in the circuits. Take it to a reputable repair person or check my website www.micromendllc.com
Feb 25, 2010 | Acer AL1706AB LCD Monitor
At start up the AL1706 monitor stays black and the green light blinks on and off. I have to restart four or five times before it eventually works
cyndommett, If not into repair work, and can afford trade for new, GET NEW ONE if current AL1706 is 4, 5, 6, years old. To understand your monitor's problem, spend an hour or two reading my and other lcd monitor tech's FIXYA profile's and testimonials. Then and only then will you have a handle on what options are at your disposal and the reason why your unit has FAILED. Bye for now. 12fixlouie
Feb 19, 2010 | Acer Computers & Internet
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Acer AL1706 A monitor powers up green light is on but screen blinks out
you have a bad power supply, it maybe fixed. you have bad back lights in the screen, usally too expensive to replace with the cost of labor. you have a bad invertor, this will start the back lights. you need to open the rear cover and look at the power supply to see if you can find a burned componet or exploded componet. if you see a bad , burned componet a local electronics repair shop usually can fix it.
Oct 27, 2009 | Acer AL1706AB LCD Monitor
Acer AL1706AB LCD Monitor Logo
242 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
