Question about Frigidaire Refrigerators
Frigidaire #GLHS35EHSB6 This has been an ongoing problem for 3 months. All of a sudden the frig starts making loud noises coming from the evaporative fan and motor. Sometimes the noise level sounds like a snowblower. If we leave the frig on it will eventually turn itself off. We have had two fans and motors replaced. At this point we have stopped unloading the food and just turn the frig off for 5 or 10 minutes and then turn it back on. We have to unplug it as the off/on button does not work when this is happening. the repairs have worked for a month, 2 weeks and 2 days. The last on and off worked for 12 hours. It appears to be a faulty part or a poor design. We are at a loss as to what to do....and spending $200 for a non fix.
    Genius:
  • Frigidaire Master
  • 2,491 Answers
Keep in mind. If you know how to fix is good but if other will fix for you then it'll cost more to fix than just buy new one.
I'll never fix the followings:
Fridge, washing machine, dryer, microwave, vacuum, TV, VCR, DVD player, toaster, electric range, dishwasher and other house appliance.
Good luck
Mai
Posted on Mar 23, 2017
SureWereMad
  • 7 Answers
SOURCE: Loud noise in freezer
maybe it has had it time! worn out! or ye could get someone to look at it!
Posted on Oct 16, 2007
  • 833 Answers
SOURCE: LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Posted on Jan 10, 2008
xMadx
  • 64 Answers
SOURCE: Fridge noise
Some larger refrigeration units have fans, but typical domestic ones usually do not, only inside the fridge/freezer compartment as such, and is used to force cold air inside the unit to help keep the contents cold.
As for the fire risk, anything electrical usually have a certain amount of risk as far as fire hazards are concerned, but certainly a lot lower then say an electrical heating element or similar device.
The noises you describe usually come from the pump itself, and i can not say if your particular fridge would have any type of fan on it not knowing the model, makes it very difficult to give any sort of prognosis - based on specific models and their typical faults/noises.
Unplugging the fridge simply stops the pump, and the noise usually returns in a minute or two as you have described, simply because the fault/noise is still there.
Pumps and repair work can be expensive, especially if the fridge is an older model and based on the average that most electrical units have a typical lifespan of 1 - 5 years depending on the quality of manufacture.
Look at it this way, a good basic unit costs anywhere from $800 - $1,500 and some of the more expensive models start from around $1,800 + ( Prices are based on Australian models and are quoted in Australian dollars )
Ok so lets break this down a little, i buy a new fridge for $1,000 and it lasts approximately 5 years, this is not expensive if you look at the cost per year which is approximately $200 / year.
Compared to the cost of repairs, typical service has a call out fee, plus parts and labor which can run into literally 100's of dollars. I guess what i am saying here is, they do wear out in time, due to fair wear and tear, and planning to buy a newer one every few years, is not such a bad idea - considering when you weigh up the possibilities of having purchased a device that can keep food cold for up to 5 years ( and in some cases longer ) for around $200 / year, planned replacement models make sense in the long run. A good way to know, is by looking at the warranty and plan to have a newer one to replace it within 12 months of the warranty's expiration, with the added bonus, you can now plan to sell the one you currently have for a few hundred dollars to help with the cost of getting a replacement.
Trust this helps you out a little, and please take the time to rate this answer, thank you.
Posted on Feb 05, 2008
OK, loud noise, error code, and poor ice machine performance...I had all three on my 25 cf french door LG frige. After I found out that 'Er FF' was a code for the fan motor, I took out the freezer drawers and found that the panel at the back of the freezer was not seated at the top. It was sagging and the fan motor was not being held up to the exhaust port above it...it was just blowing air in circles instead of through the refrigerator. I was able to push the panel at the top and get it to seat. Now it's MUCH quieter and seems to work better too.
Posted on Nov 19, 2008
godtech
  • 51 Answers
SOURCE: Model HSS25IFMCCC GE Refrig motor/fan making loud noise
UN THAW YOUR REFRIGERATOR FOR 8 HOURS IF IT STOPS GREAT IF NOT.REPLACE YOUR FAN/IT IS LOCATED BEHIND THE TOP PANEL OF YOUR FREEZER.UN PLUG YOUR FRIDGE FIRST.BUY THE PART AT A APPLIANCE PARTS STORE,AND YOU CAN DO IT IT IS A EASY REPAIR.
Posted on Jan 16, 2009
Refrig making noiise
Ask them cover deforst heater
Aug 09, 2017 | Samsung Refrigerators
They are telling it is normal because they dont want to replace it. When in all honesty it isnt. Behind the inside pannel is a protective layer of insulation with a thin layer of metal. The insulation is either not covering the entire plactic sheild. Causeing the metal to contract. It will also make it run more because it warms up faster than needed. Thats where you hear the loud noise comming from. I would demand they take it back to the store and replace it with a new one or call the better buisness beu. Hope this helped.
Nov 24, 2012 | Samsung Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Frigidaire refrigerator model FRT21LRGW5-compressor sound is loud
If it is the compressor making that sound,The compressor is bad.
A fan motor can as make this type of noise as well when going bad.
If it is the fan motor stopping,this will also shut the compressor down,due to the thermal overload protection.
Please rate this a fixya.
Feb 01, 2009 | Frigidaire FRS26R4A Side by Side...
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
