Question about Kenmore Dryers
I have a kenmore 70 series dryer (electric). It finished a load fine lastnight but will not start again now. I keep seeing postings stating to check the thermal fuse. However, I can't figure out what the thermal fuse is. I have the back of the dryer off and see several wires, but nothing that resembles a fuse. Is there a picture somewhere that I could view?
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
I have a Kenmore dryer 70 series. The buzzer won't turn off once the cycle is finished until I open the door. If I move the timer into the middle of the cycle and close the dryer, it will start again w/o...
It sounds like you have a faulty switch. The switch located behind the start button controls both the on/off setting and the buzzer. You can either replace this switch (which will likely take care of both problems) or you can take it apart and adjust the contacts. You can test them with a multimeter before and after to make sure you've got them adjusted properly.
Aug 21, 2010 | Kenmore 62602 Electric Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Kenmore 70 series washer
your lid switch is bad.you can take a pen and push it up and down to hear if it clicks.you may want to take it off and see if it has split.very easy to do.if you need help i can walk you thru it.
Mar 09, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series dryer shuts off and won't restart
IT SOUNDS AS THOUGH THE MOTOR IS OVERHEATING AND SHUTTING ITSELF OFF. THAT IS ABOUT THE ONLY THING ON THE DRYER THAT WOULD SHUT IT OFF AND NOT ALLOW IT TO START AGAIN RIGHT AWAY, BUT LET IT START AFTER A WHILE. MAKE SURE THE MOTOR TURNS FREELY. IT SHOULD NOT DRAG OR HUMM WHEN TRYING TO START.
Jan 28, 2009 | Kenmore 73952 Gas Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
