Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
One of the sensors on the side of the door is yellow, the main unit hanging in the garage has a yellow light, and it only closes if we hold the button down. otherwise light blinks and it kicks back, like something is in the way
  • 28 Answers
Senor are obstructed, gently wipe off the lenz, look for any dust, cob webs or loose wires.
make sure the eyes see each other ( look for the lites on the side) one green and one yellow, tap on to make sure they do not flicker, move them around until you have a strong steady lite and then tighten down. this should solve your problem
Posted on Oct 07, 2010
I'm having to hold the main remote button down continuously to get the door to close. It acts like something is obstructing the path, but it's clear. The sensors have a green light on one and a...
You need to hook those wires back up and then check the door sensors very closely. If the light in one of the door sensors is dim or flashing it will cause your problem.
Sep 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2 HP garage opener main part 41A5389-1 will not close door. Motor stops about 1 ft into travel on screw. Nothing blocking door - can easily open and close door manually. What to do?
If the main light flashes 10 times you have a door sensor problem. Make sure the small light on each sensor is on and not flashing. Tweak them if necessary. If the main light does not flash then you can try increasing the down force just a bit. This is a control on the side of the motor unit where the small gray antenna hangs. If this doesn't work you probably have a bad IR sensor which is a small printed circuit board just in front of the motor.
May 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
I am having the same problem. My door will close if I hold the garage door button down in the garage, but if I try to close it with the remote it goes down a quarter of the way, the light flickers then...
You have a door sensor problem. Make sure the small light on each sensor is not flickering ever so slightly. Sometimes very hard to see. Tweak them just a bit. The color of the sensors is normal.
Feb 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door won't stay closed. One sensor light is green, the other side is yellow. What can I do?
The sensor colors are normal. If the main light is flashing 10 times when the door reverses it is a sensor problem. Make sure the small light on each one is not flickering ever so slightly. Tweak them a bit to make sure. If the door is reversing when it hits the floor you need to adjust the 'down limit' control on the side of the motor unit. Turn the control in the opposite direction of the arrow printed on the cover. You might also increase the 'down force' control which is on the rear of the motor unit.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster formula 1 garage door opener keeps "bouncing" open
If the door reverses when it hits the floor it is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn this in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can always recognize a sensor problem because the main light will flash 10 times. If the main light isn't flashing it isn't a sensor problem.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Sep 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Left Sensor has yellow led & right sensor is green. Garage closes and then immediately opens. I'm assuming it's the sensor with the yellow led. How do I fix this?
If the main light flashes 10 times when the door reverses it is a sensor problem. Make sure the door isn't hitting the floor and then reversing. This problem will not cause the light to flash 10 times and can be corrected by adjusting the 'down limit' which is on the side of the motor unit.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will inconsistenly not close
It is normal for that LED by the learn button to flash randomly. It can also flash a code to help with diagnosis. The codes are 1 to 6 flashes followed by a pause and then repeats. A rapid flash is a sign it is receiving a radio signal but not necessarily the correct one to operate the door. If when your door doesn't close properly the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. The sensor must be pointed at one another and sometimes can be off just a hair and will cause intermittent problems. A slight tweaking of the sensors will cure this problem. The 'down force' adjustment can be set too low and cause the door not to close sometimes. This can be increased to overcome this problem. This problem will not cause the main light to flash. The other possibility is the RPM sensor. This is the printed circuit board that senses when the door runs into something. I have never seen one intermittent but that doesn't mean it's not possible. I hope this helps you.
Mar 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
325 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
