Question about Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator
Refrigerator Has stopped chilling/ keeping things cool and freezer has stopped freezing.We Have Cleaned all the Vents of Dust and Hair And Checked Coils Foe Freezing. What Else should be done To Ensure Itz Working Properly?
    President:
  • 3,773 Answers
Check fan in freezer. Put your ear inside and listen and feel vents for air circulation
Also you might need a hardstart relay installed on compressor.
Check with local parts dealer for the part (ERP410) Instructions are on the kit. Easier than you think to install.
If this was helpful please rate me.
IMUFO2
Posted on Sep 12, 2010
Whirlpool refrigerator model: ET8CHMXKQO 3 does not cool or freeze
unplug for 15mins after to remove the freezer to 3 feet from the wall. after those 15mins plug back
Mar 10, 2012 | Whirlpool Refrigerators
Kenmore trio freezer and fridge not cooling. we used to have problems where the fridge would be perfect but the freezer was always too cold, sometimes causing the freezer door to freeze shut. but we had a...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 19, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Frt21nnh freezer won't freeze, no frost build up... cleaned dust and hair from back periodically. can you help?
heatman101
Aug 20, 2011 | Frigidaire FRT18FS6C Top Freezer...
Ice keeps building up in freezer. Then the refrigerator stops cooling. You can get the ice off the vents in bottom back of freezer and it will start cooling again but only last a couple days before it...
Your freezer coil needs a good defrost. You are getting only a little bit of the ice off. It stops cooling because the ice acts like a insulator over the coil so it is unable to cool. Was to get this done is to empty it out and shut if off and leave the door open or maybe a hair dryer or even so warm water.
I hope this helps.
Apr 20, 2010 | Frigidaire FRT17G4B Top Freezer...
Magic Chef RB19KA-4A not cooling. Compressor is running as I can observe frost on the copper tubing. Condensor coils were cleaned off of dust but overnight the freezer temp only got down to 45 deg F. Any...
It was determined to be a malfunctioning defrost timer. The freezer box bottom was removed (not an easy thing to do) and the coils found to be a solid block of ice. The timer would not start the defrost heater, hence the freeze up. The timer was replaced and the chill box is back in action.
Jul 22, 2008 | Magic Chef Refrigerators
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Frost in freezer compartment
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Refrigerators
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
90 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
