Question about Honda Pressure Washer PSI 3000
Spark plug is fine but it doesn't fire when you pull the cord. Water hose is connected and turned on, pressure nozzle open per instructions.
    Problem Solver:
  • 18 Answers
Did you check for spark,maybe a new spark plug but check for the spark. if not check coil or wire and boot
Posted on Sep 20, 2010
Why does my Takagi tankless water heater fire up briefly when any COLD water tap is opened? Unit is new; installed per mfr's instructions; works fine when HOT water faucet is turned on.
Because when you turn on the cold water the pressure drops in the feed to the heater, so the pressure switch fires the boiler up. Call the installer back.
Oct 21, 2015 | Water Water Heaters
Unable to pull starter cord nu more then 4 inches I have removed the spark plug and released the pressure still the same what more can I do??
Dear Sir,
I understand that the engine seem jammed. Removing the spark plug was a good idea. This indicates that the engine cannot turn.
The only reason I think this happens, because the pump is jammed.
If with some method you separate the engine from the pump, you will for sure find out if the pump is jammed. Also you can release the pressure from the pump, if you have access to its valves and remove them. So trying to pull the cord with no load from the pump is the next thing you should do, with a few methods I have explained.
Regards,
M.G.
May 31, 2015 | Karcher 2500 PSI Pressure Washer
Power nozzle motor not working on my rainbow e2 vacuum?
Check plugin on the power nozzle and poles there may be some thing blocking connections
Dec 28, 2013 | Rainbow E series Canister Wet/Dry Vacuum
THE UNIT STARTS WHEN I PULL THE CORD...THE HOSE IS CONNECTED TO THE UNIT...BUT WHEN I PULL THE TRIGGER OF THE GUN...NO WATER COMES OUT
Make sure the water supply hose SCREEN where it connects to the unit is not clogged. You should get water through the nozzle without the unit running. If your not getting water with the unit off... the water supply hose is full of AIR or the screen is blocked. Loosen the water supply connection and purge the air from the hose (Clean screen if you have not already done so)
If this does not work there is more that can be done with the unloader / bypass valve. Respond here and I will help you AFTER you check the above.
Thanks for choosing FixYa,
Kelly
Jul 05, 2011 | Honda Black Max 2600 PSI Pressure Washer
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Briggs & stratton bpw 2700
Dear gcombs,
One small problem, which might sound silly, is to check that the tap of the fuel is open. There are other reasons why fuel does not come. I think that fuel is not coming, or on the contrary, it could be that too much fuel is entering the engine. So you must check for a choke correction(if it has one). I am blaming the fuel system, because you said that the spark plug, sparks really well. A wrong grade or type of fuel could also be the cause. Also I suggest as you are trying to start the engine and adjusting and checking the fuel system...this must be done with no load at all. So remove the gun(or open it without nozzle...but better to remove the gun, so you have both hands on machine)....and you can supply water if you want. But work and test with NO LOAD!!
fulltech.
Oct 29, 2008 | Garden
Honda Pressure Washer PSI 3000 Logo
140 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
